Cases Xigmatek Asgard whats your views ???
Discussion in 'Hardware' started by winter zombie, 2 Feb 2011.
  1. winter zombie
    winter zombie New Member
    30 Jan 2011
  2. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Personally I would go for the Antec 100 as based on pictures alone it appears to have better cable management and comes with 2 fans as standard. The Antec 100 is slightly more expensive at £42 but worth it IMO.
    The price of that case is certainly appealing for a budget build base though.
  3. rob the bank
    rob the bank New Member
    13 Mar 2010
    HI the Midguard is a much better case, thats the Xigmatec to go for.
    Built many systems in that, much better then the small Antec 300, much neater and better cooling.
  4. Parge
    16 Jul 2010
    I think for that price its a freaking steal!
  5. asteldian
    asteldian Member
    13 Jan 2011
  6. Throbbi
    Throbbi New Member
    10 Sep 2009
    Can't comment on the Asgard but i can say that i built a rig for a friend not too long ago using an Antec 300 and, considering the reputation of Antec, the cable management was horrible (admittedly using a captive PSU). Not only was there no options for running behind the motherboard tray etc. i found there to be very little in the way of points to use cables ties on resulting in a neat arrangement but all visible and with ties through unused 5.25 bays and the like.
    Apart from that cooling is decent and, in my opinion at least, it looks nicer but going by price and other peoples comments i'd definitely go with the Asgard or Antec 100.
    That Coolermaster looks very nice for the price though.
  7. Singularity
    Singularity ******* Operator from Hell
    2 Mar 2008
    I like the Asgard. Not had much contact with it, but from what I've seen, looks more than comparable with the lower end CM offerings. And, as for the Antec 300, I personally think it's design is quite aged now - there's better options for the price...
    For this price, I'd definitely go with the Asgard ;)
  8. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    I've built a pc in the antec 300 and the asguard and would deffo go or the asguard Everytime
  9. K404
    K404 It IS cold and it IS fast
    11 Sep 2006
  10. Instagib
    Instagib Well-Known Member
    12 Mar 2010
    The Asgard is pretty nice. I have one for a second rig.
    Just bear in mind that it is cheap for a reason; the metal used in the construction is a little on the thin and flimsy side. Also to get the most of it, it is really essential to add an extra fan to the rear.
    For the money though, I've been really happy with mine.
  11. winter zombie
    30 Jan 2011
    WoW all good comments.
    thanks guys, i think im going to get this case. it will also save me £20 now im not going for the antec 300 so that extra £20 can be spent on something else.
    Thank You All :)
  12. barney magru
    barney magru New Member
    6 Oct 2010
    Yeah should be great mate, think I'll pick one up sometime soon for the second hand budget gaming rig I'm looking at building for my brother. Seems fantastic value for money ;)
    Good luck with your system
