Hardware Xigmatek Midgard II Review
Discussion in 'Article Discussion' started by Baz, 9 Jan 2013.
  1. Baz
    Baz I work for Corsair
    13 Jan 2005
  2. David
    7 Apr 2009
    Would you say it's possible to mount a 45-50mm thick rad in the roofspace and mount exhausting fans underneath? Depending on the layout of your motherboard, it looks possible from the pics.
    I do like this case - there's a lot on offer for the money.
  3. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    By the looks of the mounting screw points for the MB I would doubt it as they seem to be as far to the edge as they can go. I'll wait for BT to confirm though... :)
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    I'm not in the labs today so I can't answer definitely, but I'd say almost certainly not. There really didn't look to be enough space for anything beneath the recessed roof section, it appears to be designed so that everything sits on top of it. But if I remember then I'll confirm tomorrow :)
  5. SchizoFrog
    5 May 2009
    If not Dogbert666, would it be possible to contact/request for a larger roof space unit instead to accommodate water cooling rads? Maybe even as a separate purchase although this would increase the overall cost and therefore affect the overall value.
  6. David
    7 Apr 2009
    Thanks, Dogbert.
    I'm thinking that 120mm fans might fit, albeit overhanging the motherboard, I've done this before, in a different case. A lot depends on clearance for VRM sinks, the EPS 12v connector and possibly ram slots.
    It looks like it would be easy enough to mod it, by removing the mesh and making a raised area from other mesh.
    Shirty likes this.
  7. SchizoFrog
    5 May 2009
    @Spreadie: Fare enough if you have to tools and the know how. I don't though. :-(
  8. Shirty
    18 Apr 1982
    Nor does Spreadie really, he's just trying to look cool :lol:
    David likes this.
  9. David
    7 Apr 2009
    Damn you, Shirty, damn you! I will have my revenge! :grr:
    A pair of tin snips, some hot glue, with a bit of time and effort and you could make a decent job of it. It isn't that difficult. Shirty is just projecting his own ineptitude onto others. :hehe:
  10. Shirty
    18 Apr 1982
    Touché
    Nice case for the money by the way, but I'm still happy with my sleepy little P182 :)
  11. mdshann
    mdshann What's a Dremel?
    18 Nov 2010
  12. SchizoFrog
    5 May 2009
    This brings up an interesting idea... How would 2 of those 12mm fans (doubled up) do compared to a single 25mm fan? Would they cause wind turbulence and would that have a negative effect?
  13. David
    7 Apr 2009
    Those Slipstream fans have zero static pressure and poor airflow = absolutely useless for a radiator, unfortunately.
  14. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    i quite like the case,
    looks very shinobi-esqe
  15. SinxarKnights
    SinxarKnights Minimodder
    21 Jan 2007
    Haha! I thought that was an 8 track sticking out of the top on the first page!
  16. Dogbert666
    17 Jan 2010
    As suspected, with a motherboard mounted there is *very* little room beneath that roof mount for anything to fit - even the ends of the RAM slots were in the way when I tried to put a normal sized fan in, and the Northbridge heatsink was nearly touching the edge. I doubt you'll find many if any boards where you'd be able to fit anything more than one of those half size fans someone mentioned, but as was also said their lack of static pressure/airflow will make them poor choices for rad cooling.
    Shirty and David like this.
  17. David
    7 Apr 2009
    Thanks for taking the time to go back and check it out, Dogbert. It is appreciated. :thumb:
  18. Shirty
    18 Apr 1982
    Rep for going the extra mile Matthew :clap:
  19. Dogbert666
    17 Jan 2010
    No worries, cheers guys :)
  20. MrJim
    MrJim What's a Dremel?
    9 Mar 2011
    Great review, definitely a case to look when I get around to my next build.
    On a side-note it's interesting the BT found the air cooling of the Corsair 200R to be so poor. I've just been reading a review of the 200R over at HardOCP, who found the air cooling to be excellent compared to other budget cases. Obviously there will be methodological differences between websites as to how they test air cooling, but it seems odd that their conclusions can vary so wildly?
Tags: Add Tags
