Development XML (transform) in PHP 4?
Discussion in 'Software' started by jezmck, 14 Sep 2005.
  1. jezmck
    jezmck Minimodder
    25 Sep 2003
    Hi guys,
    my host has refused to upgrade to PHP 5, and hence I can't use its included XML processing.
    [bizarrely, the version jumped from 4.3.11 to 4.4.0 for a short while between me asking and them saying no]
    Is there anyway I can add the support through files?
    Or any other way I can do a transform through PHP?
    TIA,
    j
  2. Hwulex
    Hwulex What's a Dremel?
    1 Feb 2002
    You mean an XML transformation using XSL?
  3. jezmck
    jezmck Minimodder
    25 Sep 2003
    yup! :)
    I tried it on my own server (which does has PHP5) and it still didn't work:
    PHP:
    <?php
    fopen
    ('http://elsewhere.com/.../pricegraphxmldata.xml''r');
    $xml = new DOMDocument;
    $xml->load('http://elsewhere.com/.../pricegraphxmldata.xml');
    $xsl = new DOMDocument;
    $xsl->load('carbonPricesTransformJ.xslt');
    // Configure the transformer
    $proc = new XSLTProcessor;
    $proc->importStyleSheet($xsl); // attach the xsl rules
    echo $proc->transformToXML($xml);
    gives the error:
    Fatal error: Class 'XSLTProcessor' not found in ---- on line 20
    So I guess I still need to import the right bit or something.
    PS - this is currently at ---
  4. simon w
    simon w What's a Dremel?
    3 Nov 2003
