Windows XP flash drive problems no drivers
Discussion in 'Software' started by ahug4122, 13 Feb 2007.
  1. ahug4122
    ahug4122 What's a Dremel?
    16 Sep 2004
    Hi there,
    I just finished reinstalling my PC with the original window XP disc that it came with and loaded up all the drivers like normal NAV office etc SP2. I plugged in my flash drive to find that it doesn't work and more i have 3 different drives tried them all none of them seam to work?
    XP says after it tries to install the devices
    Has anyone had this problem before or know what to do to fix this.
  2. DougEdey
    5 Jul 2005
    What flash drive are you using?
