Windows XP SP2 crashes PC.. Help?
Discussion in 'Software' started by Saner, 7 Sep 2004.
  1. Saner
    Saner What's a Dremel?
    30 Sep 2003
    Everytime I install SP2 onto Win XP Pro after the restart, I log on, and as soon as it displays the desktop it crashes giving me a BSD telling me there a prob with win32 something or other then the blurb about restart your PG if this happens again contact administrator etc, with the physical memory dump at the bottom.
    Now i've tryed the verion of SP" I recived with PCGamer, and also the offical windows update one. This is all after giving the PC a spring clean.
    What i've had to do is start up in Safe Mode, which it doesnt always allow, and uninstall SP2. But I would like to have it successfully installed, so... any ideas?
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    format c:
    install windoze
    install sp1a
    DONT GO NEAR SP2
  3. penski
    penski BodMod
    29 Aug 2002
    Call us: 0845 090 2025
    alternately, boot into safe mode with command prompt, go to C:\WINDOWS\$NTServicePackUninstall$\spuninst\spuninst.exe to uninstall SP2, go to www.microsoft.com/downloads and get the version for IT Pros & developers, download it to your desktop, disconnect your PC from the net (physically), disable your AV and Firewall, remove all peripherals, double click the *.exe and install anew.
    *n
  4. penski
    penski BodMod
    29 Aug 2002
    SP2 is great, all issues are solvable and we get about 2 calls a day. Either you're all to geeky and withdrawn to actually ask for help or all of these 'issues' don't actually exist.
    *n
    PS: both of those calls each day are down to third party software.
  5. Saner
    30 Sep 2003
    Okay, i've managed to uninstall SP2 in add/remove hardware and am currently downloading the version of SP2 to recomemded, how does it differ?
  6. penski
    penski BodMod
    29 Aug 2002
    The Windows update version looks at your PC and only d/ls what it thinks you need - the full d/l gives you EVERYTHING.
    *n
  7. Saner
    30 Sep 2003
    Okay, given the PC anther quick clean, will unhook printer, scanner and camera, disable firewall and AV, unhook broadband. Set system restore point... ... and pray :worried:
  8. henson0115
    henson0115 Banned
    16 Apr 2004
    i thought service pack 2 was to reduce problems not give u more since i took mine off i left it off cause i wouldnt let me download and that was both times i installed it
  9. penski
    penski BodMod
    29 Aug 2002
    Wouldn't let you download what?
    Had you set the program in the firewall exceptions?
    *n
  10. Saner
    30 Sep 2003
    Didnt work :sigh:
    [​IMG] [​IMG]
  11. Enak
    Enak Also known as Kane
    23 Jul 2002
    Unplug your USB devices
  12. Saner
    30 Sep 2003
    including mouse and keyboard?...
  13. Enak
    23 Jul 2002
    Use adaptors if you can
  14. [cibyr]
    [cibyr] Sometimes posts here
    30 Nov 2003
    It installed just fine on my very tweaked machine, with USB keyboard and mouse and pretty much nothing standard. Also installed fine on my parents reasonable-standard PC, and my dad's very standard work PC.
    Then I get to my sister's computer. Pretty standard, but I don't know *what* she does to that computer. Installed SP2 on it and I just refuses to boot. Only way to get to it work at all is a repair installation. I'm still emailing MS trying to get a fix - thankfully they're providing free email support for all SP2 issues. Otherwise I'd probably just nuke the damm thing.
  15. felix the cat
    11 Jan 2002
    what about the long list of programs that dont work afterwards?
    just because i know how to disable services and fiddle around with my registry allowing me to get past all the bs in sp2, doesnt mean everyone else does...so for the greater population it doesnt actually help that much....
  16. Enak
    23 Jul 2002
    Have you managed to try it without usb devices connected?
  17. penski
    penski BodMod
    29 Aug 2002
    You do know that list is 'possible conflicts' and 90% of the software on there has a patch don't you?
    *n
  18. felix the cat
    11 Jan 2002
    to true...my main issue is that i get to go through code that worked (compiled/ran) fine on sp1a but now refuses to on sp2...but then again im not a big winblows fan, so dont expect much enthusiam out of me...
    i guess all in all it aint too bad, and that for most people the "security centre" will do more good then harm, i just think they have done a piss poor job, and for people like moi its just hassle that i dont need, in trying to get rid of their firewall and other silly services they have added...dont get me wrong the whole windows update, service packs, security centre are all great ideas, and im sure theres more good then bad, but for me they just cause grief as i think the implementation is not undertaken correctly, the code not tested enough, and releasing it to the public came in little drops n drabs....that just my opinion though, as im sure working in IT properly you get a much better idea of how it works/doesnt for most people....
  19. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    Not a fan of SP2 here, installed the network install to a production machine (luckily freshly ghosted), totally hosed the system. Constant BSODs. Went back to 1a with that one.
    Did a fresh install on a basic test box, no extra devices, no firewalls, no a/v.. Worked okay for about a day, and now the infamous BSOD.. Seems to be all memory pool header errors.. (all equipment in this box is known-good).
    I'm just going to quietly wait for 2a to come.. Anyone remember the NT days and the h**l that was unleashed with SP6, then SP6a came out? :)
    That will be $.02 now.
    -scoob8000
  20. Saner
    30 Sep 2003
    I did not, given up with SP2, will be rebuilding all my PC's in a few weeks time, so i'll try again that time round.
