Windows XP-theme
Discussion in 'Software' started by 0013, 24 Oct 2004.
  1. 0013
    0013 What's a Dremel?
    7 Mar 2004
    what i basically mean to get is the XP Standard theme, but not in blue, silver or olive green but in black/dark grey , i don't want to install any additional programs either ... just done a clean install and trying to keep it clean as long as possible
    ive looked through deviantart.com and fund many nice and shiney stuff, but all i want is a calm black version of the toolbars ...
    all windows itself does is send you through to a site to order windoze "plus!"
    well .. had that for win 95 and that was a waste of money ...
    can anyone give a hint/link for this problem ?
    tnx
  2. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    well, the only good way is to put in a modified uxtheme.dll (you have to do it in safe mod/another windows install)
    you could of course slipstream the modified one into a cd, which would give you the modified one in a fresh install :)
  3. 0013
    7 Mar 2004
    tnx for the reply... i got myself a pre SP1 copy of uxtheme.dll and replaced it through the recovery console ... resulting in the inability to use both the standard toolbar skins and the one i downloaded so i put my old one back for now ...
    anything else i can try ?
    i used this one btw afaik it misses the "*.theme" file XP needs ...
    i have alteady tried to edit the existing one(luna) so it refers to the folder i use for this one ... resulted in no toolbars at all .
    http://xpmania.pro-networks.org/themes/XP Black Final 2.zip
  4. Atomic
    Atomic Gerwaff
    6 May 2002
  5. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    I patched uxtheme.dll in normal windows, using a program called <Dammit, I just deleted it, can't remember the name>. Oh well. But for the record, it is do-able.
  6. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    That would be a little utility called 'replacer' (i sent him it) (Link) It allows you to replace protected files in windows without any hastle :)
  7. 0013
    7 Mar 2004
    tnx, i'll give it all a try ...
  8. B.Psycho8
    B.Psycho8 What's a Dremel?
    8 Aug 2004
    i have a very nice black theme w/ style xp, got it off of themexp
  9. 1st time modder
    1st time modder What's a Dremel?
    21 Dec 2003
    psycho, if you read the post, you would realize that he doesnt want any programs running in the background. Although i do agree that style xp rocks, its still not what he is looking for.
  10. B.Psycho8
    8 Aug 2004
    it doesnt run in background :) you just install it then never run style xp again
