Windows XP to 7 using "hidden" Windows folder
Discussion in 'Software' started by ModSquid, 6 Oct 2011.
  1. ModSquid
    ModSquid Modder
    16 Apr 2011
    Recently I looked into upgrading from XP to 7 and stumbled across a webpage that showed how to do this using some sort of hidden Windows folder, thereby negating the need to reinstall your apps and programs once migration was complete.
    I'm trying to find this page again but can't seem to locate it (now kicking myself for not bookmarking it at the time) - can anyone help?
    Cheers,
    Squiddy
  2. DieselPower
    DieselPower What's a Dremel?
    9 Apr 2011
  3. thehippoz
    thehippoz What's a Dremel?
    19 Dec 2008
    never used easy transfer.. but that's pretty cool
  4. fdbh96
    fdbh96 What's a Dremel?
    29 May 2011
    Really isnt, used it and it makes a new install feel like the old one.
  5. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
  6. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    I didnt think you could 'upgrade' from XP to W7. I think you need a fresh install
  7. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    It is a fresh install of the new OS, but it means you don't have to re-download all your programs you currently have installed.
    That said, I'd just make a list of all the programs, note any registry keys required ( for purchased licenses ), then redownload them anyway- will probably be quicker regardless and wont carry over any unnecessary rubbish.
  8. ModSquid
    ModSquid Modder
    16 Apr 2011
    It's not actually the Windows Easy Transfer or any other Windows tool I was on about - more a bit of jiggery-pokery using the Windows.old folder (I think). I'll keep looking, as I seem to remember it negating the need to look in the registry etc..
    Incidentally, how would you retrieve keys for licenses from there?
  9. Teelzebub
    27 Nov 2009
    Think you right I'm sure you cant upgrade from XP to W7
  10. ModSquid
    ModSquid Modder
    16 Apr 2011
    Yeah, it's not a straight upgrade as such. It's a fresh install of 7, as you suggest, but then there's apparently a way of moving all programs and applications without having to reinstall.
    I'll keep digging and see if I can find the link...
  11. matt_lumley
    matt_lumley You're only supposed to...
    28 Apr 2010
    windows.old is created when you do an upgrade install, it keeps all your old stuff on the HDD incase you forgot to back something up etc but all the programs etc still need to be installed again to put them into the new OS :)
  12. Picky88
    Picky88 What's a Dremel?
    18 Apr 2010
    Even if you can force windows 7 to use your program files folder from xp, its likely to be really buggy, as many applications will reference dll files, etc found in xp. You are going to make it alot more complicated, when the idea is to try and save time. Do as SuicideNeil says, get your licence keys and reinstall, it will end up quicker in the long run honestly!
  13. SuicideNeil
    17 Aug 2009
    Meh, window.old was something I looked at after upgrading from XP to 7; retrieved any files & pictures I wanted that weren't already on my external backup, then deleted it whole-sale, re-downloaded all my programs that I made a list of in notepad.
    As for license keys- note them down before you do the upgrade, otherwise you can retrieve them via email usually from the site/company you bought the program from originally ( since they usually make you create an account or send your email in order to send you the license key ).
  14. ModSquid
    ModSquid Modder
    16 Apr 2011
    Point taken - cheers. How do you retrieve your keys from the registry, though?
  15. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
  16. ModSquid
    ModSquid Modder
    16 Apr 2011
    Cheers Noiz - will give it a shot...
  17. noizdaemon666
    15 Jun 2010
    The free version does only work with Windows keys and office keys, if you're after different ones then you'll need something different. Either the paid for version or something else. I've never found a program that's free that reads loads of keys from the registry. hence I have the 'paid for' version just in case. It might be possible to do it manually, but I've never tried.
