Windows XP to Vista to W7?
Discussion in 'Software' started by Digitalize-, 4 May 2009.
  1. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Currently on XP 32 Bit, got the system all up and running nicely, and now want to go to W7 RC1.
    Can i upgrade to Vista without a Product Key, then upgrade to W7 64 Bit? and Keep Steam, Games etc?
  2. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Can't you install W7 over XP?
    Why don't you backup the steam games and then reinstall, saves downloading again
  3. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    It won't work as good as you may think. The drivers for XP are a bit different than those for Vista/win7. The same goes for programs, since vista/win7 have a ever so slightly different file structure. It's easier to just reinstall. Backup + reinstall shouldn't take you much longer than a couple of hours tops.
  4. Digitalize-
    23 Apr 2009
    Hrrrmmmfff >.<
    I Guess a Reinstall would be best, how do i go around backing up Games?
  5. GoodBytes
    20 Jan 2007
    Look on the internet for each game where they save the game saved games. The problem is with XP complete lack of folder organization, developers just through them anywhere. In Vista/Win7 you have a nice folder called Saved Game in your profile folder (see how nice it is organized), but sadly gamer developers are too busy jacking off and still do their own way.
    If the game has Windows Live, then I THINK the saved game is saved online. So when you re-install the game and log back in, it should download your save game. However, if you created a offline account, then you are screwed, because the saved games are encrypted and locked down to your system, so if you re-install the game or XP, then you permanently lose your saved game. See how Microsoft is divided in their ideas form each department.
    As for Steam, you right click on your game launcher within Steam and select backup game. I don't know how to restore the game and how it works exactly.
  6. Digitalize-
    23 Apr 2009
    Ok , I have W7 on my MacBook pro, I will investigate restoring games from steam backup tomorrow, I know DOW2 and COD4 I had to copy some files over, aswell as GTA3, but those were the only games I had save data for.
  7. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Ohh I remember another forum had a sticky about this... Let's see... Oh yea!
  8. Smilodon
    25 Mar 2003
    Nope. I still can't figure out what the point of GFWL actually do. It sure as hell doesn't save anything...
    Anyway, to transport the savegames for GTA IV you just go to C:\Users\<user name>\AppData\Local\Rockstar Games\GTA IV\savegames
    The "AppData" folder is hidden.
    Just copy the contents in the "savegames" folder to a temporary folder. Then you start a new game in your new installation (Go far enough that you start driving a car). Quit the game, and replace the new savegame files with the old ones.
    I have done this a couple of times, and it works just fine.
  9. GoodBytes
    20 Jan 2007
    When I did this, I got "Unable to load game".
    I will try mm vr way, soon.
  10. Digitalize-
    23 Apr 2009
    I Dont have GTA4, i have GTA3....
  11. GoodBytes
    20 Jan 2007
    Trying selling non-legit software and hoping someone would visit your spamy-link, eh?
  12. Digitalize-
    23 Apr 2009
    Spam LOL.
    and, close thread, im typing this on Windows 7, biggest hassle was getting all the steam games to work, but they do now ^^
  13. trig
    trig god's little mistake
    10 Aug 2006
    figured i would just hijack this thread instead of starting a new one. see how it works...
    i play l4d, so what issues did you have getting it to work? what did you do to fix? did you make a driver cd to use after the install of windows 7?
