Windows XP Twice in OS list
Discussion in 'Software' started by Mr. Beta, 29 Feb 2004.
  1. Mr. Beta
    Mr. Beta What's a Dremel?
    27 Feb 2004
    Hey,
    I'm new to the forum and have a question.
    When my computer boots up and goes to the OS choosing menu, XP home shows up twice. I don't know if it's installed twice or what but I want to remove it. How would I go about doing that?
    All feedback welcome and appreciated.
    Thanks
  2. Zot Rgul8ed
    Zot Rgul8ed What's a Dremel?
    14 Feb 2004
    start>run>type msconfig>boot.ini>under operating systems you should see both windows installs, check the bootpaths and remove the one that is incorrect. if it doesnt say either is missing then youll have to remove the one you dont use, i forget how to do that though, so someone else will have to help you with that
  3. Mr. Beta
    27 Feb 2004
    Just what I needed, Thanks. :thumb:
