Windows XP won't boot, can't use recovery console
Discussion in 'Software' started by ozstrike, 4 Jun 2007.
  1. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    After a botched install of Ubuntu on my computer, I can now longer boot into XP. I get the 'unmountable boot volume' error.
    It appears that my XP partition is intact, as I can access it using the Ubuntu livecd, and everything seems fine. I just think the boot.ini is messed up.
    I tried fixing it using the recovery console from my XP cd, but it hangs on "examining disk...on viasraid". (yes I have installed the SATA drivers)
    I think that all I have to do is edit my boot.ini so that windows can 'find itself' again, but I can't do this if I can't access the recovery console.
    Any ideas on how to fix it?
  2. Spaceraver
    Spaceraver Ultralurker
    19 Jan 2006
    cant you use the ubuntu cd and gedit boot.ini?
  3. ozstrike
    19 Sep 2004
    Can't edit it, because it's an NTFS partition.
    I think I'm going to have to format :(
  4. DougEdey
    5 Jul 2005
    When you say "hangs", how long did you leave it for?
  5. ozstrike
    19 Sep 2004
    5-10 Minutes maybe? I'll try leaving it for longer later.
  6. ozstrike
    19 Sep 2004
    Right, fixboot and fixmbr won't work. I think it's screwed :(
    Edit: yeah, recovery console is showing it to be a fat16 volume. Yet its a 200gb partition :lol:
