Windows XPsp2 Pro and 4gig RAM
Discussion in 'Software' started by Carlk, 31 May 2005.
  1. Carlk
    Carlk What's a Dremel?
    10 May 2004
    Hey wonder if anyone can help... got a pc here with 4gig ram (dont ask me why they need so much) and windows only see's it as 2.75. is there anyway we can make it see all 4gig??
    Cheers for any help
    Carl
  2. Atomic
    Atomic Gerwaff
    6 May 2002
    Hardware specs?
  3. Carlk
    10 May 2004
    ermmmm... 4x 300gb sata, 2x6600gt , 4gig ram, Asus A8N-nf4, FX55.
  4. kenco_uk
    28 Nov 2003
    Do they run the internet?
    edit: Ah, I think I found the answer. Have you tried switching the page file off? I would assume that it's set to 1.25GB.
  5. r00t69
    r00t69 What's a Dremel?
    2 Apr 2005
    Well WinXP does support 4GB. Does the BIOS see all 4GB? Is it a PCI-Express board as this will explain some of the missing memory. Also have you added the /PAE switch to the boot.ini?
  6. Carlk
    10 May 2004
    yup all 4gig in BIOS and yeap there running the internet
  7. r00t69
    2 Apr 2005
    Did you check for the /PAE switch in boot.ini. If it's not there add it at the very end. Should look something like this.
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /PAE
    BTW the boot.ini is a hidden system file normaly at the root of C:
  8. kenco_uk
    28 Nov 2003
    The /PAE switch applies to certain versions of Windows only it would seem, according to this.
    Just in case you missed it btw:
  9. Carlk
    10 May 2004
    yup, PF turned off... im gunna try the boot.ini
    Cheers
  10. Firehed
    15 Feb 2004
    In the A8N there's some bios setting like "remap ram over 4G", try finding and enabling it.
