Graphics XT1900XT Power usage?
Discussion in 'Hardware' started by OldY, 30 Aug 2006.
  1. OldY
    OldY What's a Dremel?
    10 Mar 2006
    In a couple of weeks i'll be building a Conroe Shuttle system and was wondering if a 400Watt PSU would be able to handle a a E6300 and a XT1900XT? If not, back to drawing board!!!
  2. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Depends on the make of the psu.
  3. lcdguy
    lcdguy Minimodder
    25 May 2004
    i agree depends on the make. if it's a quality PSU then you should be fine as long as you don't add to much more. also you should also find out what the amp rating for the +12v rail(s) is on that power supply you'll want atleast 30-40 amps. (the more the better)
  4. OldY
    10 Mar 2006
    Here is the spec of the PSU:
    SilentX 400 Watt mini PSU with switch, supports 110/240V
    connectors: 2x3 pin (CPU power), 2x4 pin (mainboard power)
    Active PFC circuit (Power Factor Correction)
    EMI certified: FCC, CE, BSMI, C-Tick
    Safety certified: UL, TüV, CB, BSMI
  5. Tim S
    Tim S OG
    8 Nov 2001
    I think 27A is the recommended amount.
  6. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    remember shuttle PSU's are often very efficient. therefore even though its a 400W PSU it will work fine.
