Graphics XXX vs Black- Radeon 5850
Discussion in 'Hardware' started by Casefan, 26 Nov 2009.
  1. Casefan
    Casefan One Man Army
    19 Aug 2009
    Hi everyone,
    I'm looking at buying a Radeon HD 5850 graphics card at Christmas.
    I have a choice between these two: The XFX Radeon HD 5850 XXX Edition which has a 755mhz core clock, and 4500mhz memory clock, and the XFX Radeon HD 5850 Black Edition, which has a 4000mhz memory clock, and 765mhz core clock. Otherwise these cards are identical (The Black Edition costs £8 more)
    So the question is, which is worth more, a 10mhz Core Clock increase of a 500mhz memory clock increase? I heard core clocks are more important, but surely this memory increase is huge in comparison.
    Thanks in advance,
    Casefan :D
  2. Horizon
    Horizon Dremel Worthy
    30 May 2008
    get the cheaper card and raise the clocks yourself, black edition if i had to choose.
  3. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    The black edition has its memory clocked at 1.25ghz quad pumped to 4.5ghz just the same as the xxx version.
    I dont think 10mhz on the core is worth £8 as all other specs remain the same. The black editions are usually cherry picked however the xxx cards are too. But for a chip to maike a black edition over a xxx I would say it should overclock slightly better which makes the £8 more appealing.
    Scan as such have it listed wrong mate.
    Andy
  4. Casefan
    19 Aug 2009
    I've never really overclocked a GPU before, would it really be worth it?
    Should I just go for the cheaper XXX then?
    Thanks for responses.
  5. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Overclocking (at it's most basic) is incredibly easy, just do it using ATi's OverDrive (built in to the driver). Yeah, the clocks won't get much higher (depending on the BIOS of the card), but you can easily make up the £8 worth of clock difference.
    However, as Andrew8200m has said, the higher clocked version (£8 more) is probably speed binned, so if you were to overclock properly, it should make it further.
    Hope that helps :thumb:
  6. Casefan
    19 Aug 2009
    Ok, thank you very much everyone.
    So at stock, which one of these cards is faster?
  7. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    The Black edition from what I've hear (think it was the latest hardware podcast) allows you to register your card with XFX to download a black editon owner only voltage utility like Asus' Voltage Tweak.
    Ljs likes this.
