Hey guys I'm about to order 4 of these fans for my case, I was wondering what you would rate these guys out of 10? http://www.directcanada.com/products/?sku=23420AC9140
Don't know about those ones but i've got a pair of the 1200rpm non-led ones and they're great. More airflow and less noise than the thermaltake ones which came with my case. And they're dirt cheap
Can't go wrong with the Yate Loon fans. They're inexpensive compared to many others, good airflow and quiet. Been using them quite a bit over the last year or so.
very good bang for bucks, and not bad performance either, totally a good buy. push-pulling on my TRUE at the moment.
A bargain fan but needs a controller. Get the black plastic frame if you want lowest noise, clear plastic is harder and transmits vibration more. And they need undervolting to around 7V if you want near-silence.
He means your ears would benefit, if they were plugged into a fan controller. They will however run straight from a 4 pin molex or 3 pin header.
hm? i mean $10, that's what the DC link in dorksterr's post says and it's too much. also, cpemma's a girl?
oops i misread what you wrote. I thought you said the ones you linked to were expensive at $10. sorry and about cpemma being a girl. really?
