Planning Yes I know HTPC's are supposed to be dead but......
Discussion in 'Modding' started by Snips, 22 Jan 2012.
  1. Snips
    Snips I can do dat, giz a job
    14 Sep 2010
    I have a bloody nice Antec Fusion 430 Silver faceplate case inc. BluRay that is just too good to get rid of. I need a uATX board configuration so what do you guys suggest?
    I'd like a nice quiet system to sit idle under the TV but I'd like it to be fully functional. So a nice quiet powerful GPU is a must.
    I'm not afraid of modding the case.
    I'm open as to the budget. I'd favour an Intel/Nvidia config but if you would like to convince me otherwise, I'm not going to dismiss any good practical suggestion.
    Thanking you all in advance for any assistance :thumb:
  2. KidMod-Southpaw
    28 Sep 2010
    HTPC's aren't the slightest bit dead...
  3. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Was thinking the same, they're just starting! I'll be building a few for family soon enough, people see how awesome they are when they come round to mine
    Snips likes this.
  4. KidMod-Southpaw
    28 Sep 2010
    You should also remember that- that case supports MATX boards, and that's your best option as a good UATX board is rarely available.
    If you get a decent Sandy Bridge setup, the onboard GPU from that will be fine! Here's a basket I put together: http://www.scan.co.uk/savedbasket/743a7546db08467497beb1a26d3656c2
    Snips likes this.
  5. Snips
    14 Sep 2010
    The dead thing was coming from media players that are becoming really popular and cheaper. However, that Sandybridge looks just right.
    I had a system with a passive 8600GT which worked really well and silent but could also handle games. Any ideas if I was to throw in a GPU?
  6. KidMod-Southpaw
    28 Sep 2010
    Well, you'll want a single slot GPU to save space I take it, and something capable but not too powerful to save on heat and power?
    Here's a great option:
    http://www.scan.co.uk/products/1gb-...-1800mhz-192-cores-dual-link-dvi-i-d-sub-hdmi
  7. j0rd
    j0rd FLOSS folder
    13 May 2011
    what OS? If your running something Like XBMC live (or any Linux based HTPC distro), then your best bet is a Nvidia GPU w/ the binary blob, if its windows (and i just realized u mentioned gaming so im guessing it may well be) then i defer to people smarter than myself.
  8. Snips
    14 Sep 2010
    Do you know what it's like for noise KidMod?
    I have an ATi 5770 here but it's not the quietest
  9. KidMod-Southpaw
    28 Sep 2010
    Depends what you'll be playing. You say it will be at lower resolutions, which means you won't be taxing the card very much, so the fan speed will stay low. :)
  10. KidMod-Southpaw
    28 Sep 2010
  11. Snips
    14 Sep 2010
    Cheers matey :thumb:
