Build Advice Yes! It's another First New Build advice thread!
Discussion in 'Hardware' started by QuietlyConfident, 9 Sep 2010.
  1. QuietlyConfident
    QuietlyConfident New Member
    14 Jun 2009
    Hey guys,
    I'm finally allowing myself the indulgence of building my own computer using some good hardware; I've been stuck using underpowered business laptops for years now, and it's driving me insane.
    Thanks to the excellent build guides bit-tech has, I've pretty much sorted out exactly what I want; with the only two parts to decide on being the motherboard and CPU.
    I've already stretched my £1100 budget to the maximum, but could probably afford another £50 or so.
    The main uses will be gaming and heavy photoshop work on this PC.
    Not using any parts from my laptops, obviously.
    The monitor I've chosen is native at 1920x1200.
    Probably not going to be overclocking; I've no idea how to do it.
    So far, the parts I'm looking at buying are:
    Gigabyte GTX 460 Graphics Card at £172.99
    http://www.ebuyer.com/product/232853
    Corsair Memory Dominator 4GB (2x2GB) DDR3 RAM at £78.60
    http://www.scan.co.uk/Products/4GB-(2x2GB)-Corsair-Dominator-DDR3-PC3-12800-(1600)-Non-ECC-Unbuffered-CAS-9-9-9-24-DHX-165v
    Antec TruePower New 650W PSU at £77.99
    http://www.ebuyer.com/product/159920
    Titan Fenrir TTC-NK85TZ Fan at £28.78
    http://www.scan.co.uk/Products/Titan-Fenrir-V2-TTC-NK85TZ-V2-120mm-PWM-17dBAplus-HDT-CPU-Cooler-(775-1156-1366-K8-AM2-AM3)
    Xigmatek UTGARD at £64.50
    http://www.ebuyer.com/product/191871
    HP 24" IPS Monitor ZR24W at £339.97
    http://www.ebuyer.com/product/204376
    Samsung SpinPoint F3 1TB Hard Drive at £44.90
    http://www.scan.co.uk/Products/ss1TB-Samsung-HD103SJ-Spinpoint-F3-SATA-3Gb-s-7200rpm-32MB-Cache-89-ms-NCQ-OEM
    Samsung SH-S223 DVDRW Drive at £12.99
    http://www.ebuyer.com/product/145450
    Mouse, keyboard, and speakers have yet to be chosen.
    I'm entirely torn between getting an ASUS or Gigabyte motherboard; the two which I've singled out being;
    the Asus P7P55 LX at £79.37
    http://www.scan.co.uk/Products/Asus-P7P55-LX-Intel-P55-Express-S1156-PCI-E-20-(x16)-DDR3-2200(OC)-SATA-3Gb-s-SATA-RAID-ATX
    and the Gigabyte GA-P55M-UD2 at £84.20
    http://www.amazon.co.uk/dp/B002MRJ096/ref=asc_df_B002MRJ096838532?smid=A3P5ROKL5A1OLE&tag=googlecouk06-
    21&linkCode=asn&creative=22206&creativeASIN=B002MRJ09
    And finally, the CPU. Scan has a deal today, the Intel i7 870 2.93ghz is at £223.24, whereas my original choice of the Intel i7 860 2.8ghz is £210. Would the extra ghz make much difference?
    Help would be appreciated! Especially if theres anything in my current build set that I've missed or is questionable.
    EDIT: Oh yes, of course, I need a good but reasonably cheap wireless card (a wireless card would fit in there, right?). Any recommendations?
  2. adam_bagpuss
    24 Apr 2009
    looks well thought out mate so well done.
    you could get either board to be honest both are good.
    id still get the 860 as £13 for 193mhz is a joke and you wont notice anything not with gaming or photoshop.
    plus even if you dont wanna overclock you could sneak into the bios and raise the QPI by like 7 and have a 2.94Ghz CPU lol.
    shame your gunna let down your gaming by getting a wireless card though :( wired is much prefered for good pings
    if not the Abit Airpace at scan for £8 is a very good wireless G card
  3. meandmymouth
    meandmymouth Well-Known Member
    15 Sep 2009
    Looks alright, although I would try and get as many parts as possible from a single supplier as delivery costs will mount up!
    Once you have made 20 posts on here you can sign up to Scan and get free delivery with them and more often than not you will be able to find at least 2 of the above products on there Today Only deals, saving you a few extra quid too.
    Also in terms of overclocking many will be able to tell you how to add the few extra MHz onto the i7 860 and again save you a little. You can push it past 3GHz without having to change anything bust the base clock, it's pretty easy and there is plenty of support on here.
