heheh, managed to get out... it seems that there might be several ways of getting out, otherwise what are all the extra bits for that i didnt use?
http://www.fasco-csc.com/works/white/white_e.php still struggling to do this one, whats the friggin morse code for :S
Ok, so turning the gas spigot on makes the room turn white and blurry and I die. Cutting wires on the bomb kill me. I give up!
White room was indeed fairly easy, though it's a shame how it crashed. I've never understood veridian room, probably supposed to look up chinese characters, but can't be bothered. For the bomb one though.. I gave up It's weird how no matter which bomb you make blow up, it's always the same one which blows
Spoiler the trick to the bomb one is this, you think its going to be complicated due to everything involved. but its so simple you overlook it
I'm stuck on the white room one, Spoiler I fitted the light onto the bike and opened the door, but don't know what to do next.
I can't figure out the purple blocks... i'm guess something to do with the floor, but can't figure out the flashes
Spoiler you need to use the remote and the memory chips to open the various colors behind the blue door then use the stuff from under the table (long pole) to grab paper off ceiling and binoculars to view scrap of paper on the far wall gold hook from long rod to hole in wall, mirror on hook, bike light on to see paper help into purple lock to unlock gold bike key #6 starter button to crash bike into door working on crimson room now
