Electronics Yet another component IDing thread.
Discussion in 'Modding' started by OtakuHawk, 17 Dec 2005.
  1. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    hey, I need help IDing a Zener diode.
    it has a glass body, black ring on one end, and the marking "47B" in very small letters.
    I need to know what the stats are on this thing.
    what I'm TRYING to find is a 4.7V, 400mW Zener for a project. (Nixie clock, actually)
    and if this is one, great, 'cause I can't get them at Rat shack, and I really don't feel like ordering .40 worth of diodes and paying shipping from jameco.
    My google-fu has failed me. help me bit-techians. you're my only hope. :D
  2. Xiachunyi
    Xiachunyi What's a Dremel?
    3 Nov 2003
    Do you have any voltage regulators that are near/above that voltage?
    If the load resistance does not change much and does not draw much current, you could create a voltage divider.
    Do you have a local Fry's Electronics?
  3. OtakuHawk
    30 Apr 2003
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    That's a rather dangerous design, generating 220V DC from US mains with a voltage-doubler (or using rectified UK 230V) and using R1 & R2 (to spread the waste heat produced over two resistors) and the zener to get the 4.7V supply for the chips. A normal 7805 regulator won't handle that ingoing voltage, safe way is to use a small 9V transformer, rectifier bridge, smoothing and 7805 to produce 5V DC to run the chips.
    Otherwise find a 4.7V zener and don't assume anything is safe to touch. :nono:
  5. mcshaggy
    mcshaggy What's a Dremel?
    28 Mar 2004
    generally the numbers on zener diodes dont have anything to do with output voltage, for future reference. (at least on all ive come in contact with at school)
