Now before you all think I'm going to ask if I can use my gameboy lcd as somthing or other I'm not, I'm asking How does the game boy acualy work.I'm doing a report on them And I'm a little confused,Ive found these. http://home1.stofanet.dk/hvaba/gameboy/mbc5cpld/cpldcart.html http://geocities.com/vjkemp/gbcam.htm Pin - Name -Description 1 -VCC -+5 VDC 2 -? -? Connected on Gameboy, but not used on GamePaks. 3 -/RESET -Reset 4 -/WR -Write 5 -? -? Used by paging PAL on high capacity GamePaks. 6 -A0 -Address 0 7 -A1 -Address 1 8 -A2 -Address 2 9 -A3 -Address 3 10 -A4 -Address 4 11 -A5 -Address 5 12 -A6 -Address 6 13 -A7 -Address 7 14 -A8 -Address 8 15 -A9 -Address 9 16 -A10 -Address 10 17 -A11 -Address 11 18 -A12 -Address 12 19 -A13 -Address 13 20 -A14 -Address 14 21 -/CS -Chip Select 22 -D0 -Data 0 23 -D1 -Data 1 24 -D2 -Data 2 25 -D3 -Data 3 26 -D4 -Data 4 27 -D5 -Data 5 28 -D6 -Data 6 29 -D7 -Data 7 30 -/RD -Read 31 -? -? Connected on Gameboy, but not used on Game-Paks. 32 -GND -Ground And unfortunutly I dont understand a bit of it,I was hopping to make my own game some how but instead uf eeprom will a pic work. And whats it mean by data and address. wich pins controll the buttons and sound and screen.Eny help is appreciated.
ok, WTH is this all about... whats the project and whats all those schematics for? You hack nintendos network?
Sorry The project is called explorer were the kids get to choose somthing they get to reserch on and I chose gameboy.And the schematics I found on the web. I am tyring to make a game. But taking a shortcut I am wondering If eny one knows how to make one with pics. caouse I dont understand a bit of this kind of program. Code: // // Title : CPLDTEST.C // Menudriven testprogram to test the MBC5 part and the i/o // in the Xilinx CPLD. // Compiler : GBDK 2.1.0. Needs additional MBC5CPLD.H. // References : // Author : claus.bjerre@private.dk // Version : 0.1 #define ROM_TEST // Include ROM bank switch test. //#define EMULATOR // Undefine to run on the real thing #include <gb.h> #include <console.h> #include <drawing.h> #include <stdio.h> #include <stdarg.h> #define CPLD_CONF_1 #include "mbc5cpld.h" // Non-GBDK header UBYTE cpx, cpy; UBYTE ubPortAMode; #ifdef ROM_TEST_ENABLED void rom_bank_1( void ); void rom_bank_2( void ); void rom_bank_3( void ); #endif void CenterText( int row, char *txt ) { gotogxy(3,row); gprintf("%s", txt ); cpx = 10 + strlen( txt )/2; } /* CenterText */ #define NEWLINE -1 void Text( int x, int y, char *txt ) { if( y == NEWLINE ) gotogxy(x,++cpy); else gotogxy(x,y); gprintf("%s", txt ); cpx = x + strlen( txt ); cpy = y; } /* Text */ void TextAttr( int x, int y, char *txt, UBYTE a, UBYTE b, UBYTE c ) { if( y == NEWLINE ) gotogxy(x,++cpy); else gotogxy(x,y); color( a,b,c ); gprintf("%s", txt ); color( BLACK, WHITE, SOLID ); cpx = x + strlen( txt ); cpy = y; } /* TextAttr */ void DispBinary( UBYTE bte ) { char txt[2]; UBYTE i; for( i=0x80; i>=0x01; i>>=1 ) { sprintf( txt, "%c", bte & i ? '1' : '0' ); Text( cpx, cpy, txt ); } } /* DispBinary */ void DispBinaryCursor( UBYTE bte, UBYTE index, UBYTE nof_bits ) { char txt[2]; int i; bte <<= 8-nof_bits; for( i=nof_bits-1; i>=0; i-- ) { if( index == i ) color(WHITE, BLACK, SOLID); sprintf( txt, "%c", bte & 0x80 ? '1' : '0' ); bte <<= 1; Text( cpx, cpy, txt ); color(BLACK, WHITE, SOLID); } } /* DispBinaryCursor */ #define SET_BIT 1 #define CLEAR_BIT 0 void SetBit( UBYTE *dat, UBYTE ubIndex, UBYTE ubSet ) { UBYTE ubVal; ubVal = 1; for( ; ubIndex > 0; ubIndex-- ) ubVal *= 2; if( ubSet == SET_BIT ) *dat |= ubVal; else *dat &= ~ubVal; } /* SetBit */ #define XMIN 0 #define XMAX 159 #define YMIN 0 #define YMAX 143 void ClearScreen( void ) // Rediculus. Gotta find the function... { UBYTE ubI; color(WHITE, WHITE, SOLID); for( ubI = 0; ubI <= YMAX; ubI++) line( 0, ubI, XMAX, ubI); color( BLACK, WHITE, SOLID ); } /* ClearScreen */ void DispAddr( UWORD uwI, UBYTE ubBank ) { Text(2,7,"Bank "); gprintn( ubBank, 10, 0 ); Text(2,8,"Addr "); gprintln( uwI, 16, 0 ); Text(13,7,"("); gprintln( ubBank*8 + (1+uwI-0xA000)/1024, 10, 0 ); gprintf("k)"); } /* DispAddr */ void RamTest( void ) { UWORD uwI; UBYTE ubError, ubPresc, ubBank; char txt[10]; ubError = 0; ubPresc = 1; ClearScreen(); Text(1,3,"Testing cart RAM"); Text(1,5,"Zeroing"); for( ubBank = 0; ubBank < 128/8; ubBank++ ) { SWITCH_RAM_MBC5(ubBank); if( ubBank & 0x01 ) Text(cpx,cpy,"."); for( uwI = 0xA000; uwI <= 0xBFFF; uwI+=2 ) { *(UWORD *)uwI = 0x0000; } } for( ubBank = 0; ubBank < 128/8 && !ubError; ubBank++) { SWITCH_RAM_MBC5(ubBank); for( uwI = 0xA000; uwI <= 0xBFFF && !ubError; uwI++ ) { if( *(UBYTE *) uwI != 0x00 ) ubError = 1; *(UBYTE *)uwI = 0x55; if( *(UBYTE *) uwI != 0x55 ) ubError = 2; *(UBYTE *)uwI = 0xAA; if( *(UBYTE *) uwI != 0xAA ) ubError = 3; if( !--ubPresc || ubError || uwI == 0xBFFF ) { ubPresc = 252; DispAddr( uwI, ubBank ); } } } if( ubError ) { if( ubError == 1 ) Text( 2, 11, "FAIL (not zero)" ); else if( ubError == 2 ) Text( 2, 11, "FAIL (not 0x55)" ); else if( ubError == 3 ) Text( 2, 11, "FAIL (not 0xAA)" ); } else { Text( 2, 11, "PASS"); } do {} while( !joypad() ); ClearScreen(); } // RamTest #ifdef ROM_TEST void RomTest( void ) { UWORD uwI; UBYTE ubError, ubPresc, ubBank; char txt[10]; ubError = 0; ubPresc = 1; ClearScreen(); Text(1,3,"Testing cart ROM"); Text(0,5,"Switching 4000-7FFF"); cpy += 2; SWITCH_ROM_MBC5((UWORD) 1); rom_bank_1(); SWITCH_ROM_MBC5((UWORD) 2); rom_bank_2(); SWITCH_ROM_MBC5((UWORD) 3); rom_bank_3(); SWITCH_ROM_MBC5((UWORD) 0); Text( 2, 11, "Ready..."); do {} while( !joypad() ); ClearScreen(); } // RamTest #endif void LatchTest( void ) { UBYTE ubDummy; UWORD uwCnt; uwCnt = 0; ClearScreen(); Text(1,3,"Testing AA & RA"); Text(1,5,"Running..."); do { ++uwCnt; // Set AA12..15 SWITCH_RAM_MBC5( uwCnt ); // Set RA13..21 SWITCH_ROM_MBC5( uwCnt ); ubDummy = *(UBYTE *) 0x4000; } while( !joypad() ); Text(1,7,"Stopped..."); do {} while( !joypad() ); ClearScreen(); } // LatchTest() UBYTE ubCPLD_READ( UBYTE port ) { return CPLD_READ(port); } // ubCPLD_READ void ubCPLD_WRITE( UBYTE port, UBYTE data ) { CPLD_WRITE(port,data); } // ubCPLD_WRITE void SetPortAMode( UBYTE mode ) { CPLD_WRITE( PORTA_DDR, mode ); } // SetPortAMode void TogglePortAMode( void ) { ubPortAMode = (ubPortAMode == PORTA_INPUT ? PORTA_OUTPUT : PORTA_INPUT); SetPortAMode( ubPortAMode ); } // TogglePortAMode enum { SCOPE_PORTB, SCOPE_RAM, SCOPE_LATCHES, SCOPE_PORTA_MODE, SCOPE_ROM }; void main() { UBYTE a,b,c,d,e, pos; int i, iPassDir; UBYTE data, ubOutData, ubIndex, ubKey, ubKeyScope, ubPass, ubLedPresc; UBYTE ubPAOutData, ubPAIndex; UBYTE mask; char Str[20]; /* Coldstart asignments */ c=0; ubIndex = 8; ubPAIndex = 4; ubPAOutData = 0x12; ubKeyScope = SCOPE_PORTB; ubPass = 10; iPassDir = 1; ubLedPresc = 0; mask = RAM_ENABLE + IO_ENABLE; CPLD_RAMG_REGISTER( mask ); // GLobals ubPortAMode = PORTA_INPUT; do { if( ++ubLedPresc & 0x04 ) { if( mask & LED_ENABLE ) { ubLedPresc = 0; mask = RAM_ENABLE + IO_ENABLE; CPLD_RAMG_REGISTER( mask ); } else { ubLedPresc = 0x02; mask = RAM_ENABLE + IO_ENABLE + LED_ENABLE; CPLD_RAMG_REGISTER( mask ); } } ubKey = joypad(); CenterText( 1, "MBC5/CPLD Test" ); /* I'm alive bar */ #define LEN 30 #define AIR 10 if( (ubPass+=iPassDir) > YMAX-(LEN+AIR) ) iPassDir = -1; if( ubPass <= AIR ) iPassDir = 1; line( ubPass, 19, ubPass+LEN, 19 ); color(WHITE, WHITE, SOLID); plot_point( ubPass-1, 19 ); plot_point( ubPass+LEN+1, 19 ); color(BLACK, WHITE, SOLID); SetPortAMode( ubPortAMode ); pos = 3; Text( 0, pos++, "I/O input ports" ); // Display PortA 8 bit input // Not selectable TextAttr( 0, pos++, "PORTA ", BLACK, WHITE, SOLID ); #ifndef EMULATOR data = ubCPLD_READ(PORTA); #else data++; #endif DispBinary( data ); // Display PortA 4 bit output if enabled if( ubKeyScope == SCOPE_PORTA_MODE && (ubPAIndex == 4 || ubPortAMode == PORTA_INPUT )) TextAttr( 0, pos++, "PORTA ", WHITE, BLACK, SOLID ); else TextAttr( 0, pos++, "PORTA ", BLACK, LTGREY, SOLID ); if( ubPortAMode == PORTA_INPUT ) Text( cpx, cpy, " ----"); else { Text( cpx, cpy, " "); DispBinaryCursor( ubPAOutData, ubPAIndex, 4 ); } // Display PortC 8 bit input Text( 0, pos++, "PORTC "); #ifndef EMULATOR data = ubCPLD_READ(PORTC); #else ; #endif DispBinary( data ); switch( ubKeyScope ) { case SCOPE_PORTA_MODE : { if( ubKey & J_UP ) { if( ubPAIndex == 4 ) TogglePortAMode(); else SetBit( &ubPAOutData, ubPAIndex, SET_BIT ); } else if( ubKey & J_DOWN ) { if( ubPAIndex == 4 ) ubKeyScope = SCOPE_PORTB; else SetBit( &ubPAOutData, ubPAIndex, CLEAR_BIT ); } else if( ubKey & J_RIGHT && ubPortAMode == PORTA_OUTPUT ) { if( ubPAIndex-- == 0 ) ubPAIndex = 4; } else if( ubKey & J_LEFT && ubPortAMode == PORTA_OUTPUT ) { if( ++ubPAIndex == 5 ) ubPAIndex = 0; } break; } case SCOPE_PORTB : { if( ubKey & J_UP ) { if( ubIndex == 8 ) ubKeyScope = SCOPE_PORTA_MODE; else SetBit( &ubOutData, ubIndex, SET_BIT ); } else if(ubKey & J_DOWN) { if( ubIndex == 8 ) { ubKeyScope = SCOPE_RAM; } else SetBit( &ubOutData, ubIndex, CLEAR_BIT ); } else if( ubKey & J_LEFT ) { if( ++ubIndex > 8 ) ubIndex = 0; } else if( ubKey & J_RIGHT ) { if( ubIndex-- == 0 ) ubIndex = 8; } break; } case SCOPE_RAM : { if( ubKey & J_UP ) { ubKeyScope = SCOPE_PORTB; ubIndex = 8; } else if( ubKey & J_DOWN ) { ubKeyScope = SCOPE_ROM; } else if( ubKey & J_RIGHT ) { RamTest(); } break; } case SCOPE_ROM : { if( ubKey & J_UP ) { ubKeyScope = SCOPE_RAM; ubIndex = 8; } else if( ubKey & J_DOWN ) { ubKeyScope = SCOPE_LATCHES; } else if( ubKey & J_RIGHT ) { #ifdef ROM_TEST RomTest(); #endif } And thats not even all of it.
Could eny one explain what the program is doing.I know its the first half but It would give me an understanding.
Errrrrrrrrrrrrrrrrrr Try a nintendo forum possibly, maybe the geeks there could help you out.. It's all geek, I mean greek to me...
The program is in C but I cant translate it. I see were your getting with this ,seeing what pins do what and the such, I hope it works out for you.
This is what the program does: Menu Driven Test Program to test the MBC5 part and the I/O in the Xilinx CPLD. As for the pics: The top one looks like it's the main GB hardware. The second looks like the I/O interfaces to the CPU, how the cartridge is processed, how the power is inputed, how the button presses are processed, and how the audio is outputed. The third looks like how the power is supplied. The fourth is how the LCD display is hooked up. The fifth is how the memory is connected. The sixth is how the logic is implemented.
aye, What your best bet is, is to read up on computer systems. You need to get you're head round ideas such as buses, then ideas like fetch execute. Google should be able to help you there. You can't dive straight into hacking something without doing background research.
After plaing around I just realized that the gameboys cartrige ports have the same connecters as normal lcd.the data ports ,But I dont have my gameboy with me right at the moment could someone who has a bunch of extra time connect the data, wright,ect ports and see if that does enything.thanks. Edit: and program it.
Take the advice and use Google. Search for a compiler for Gameboy. You will notice most compilers and hardware are for GBA. You can purchase a 256-1GB flash cart. for the GBA from $100-250(US). If you are trying to make a cart, don't waste your time, just buy one but good luck finding one for the GB. Programming for the GBA is not that difficult, but you have to know how to program. If your pressed for money, you can make a GBA to USB cable and run the program from the MultiBoot feature on the GBA. Two versions exist: one with a PIC and a dumb cable that runs from DOS. Again use Google. I would stop asking for someone to decipher the above schematic for you. Get a good electronics book and do some research. No one is going to take the time to do it for you.
