Modding Yet another GhettoBlaster
Discussion in 'Modding' started by willek, 13 Feb 2011.
  1. willek
    willek What's a Dremel?
    19 Jan 2009
    Here is my earlier blaster, built in 2009.
    More story and building pictures here:
    http://allthemods.com/userinfo.php?userid=5&album=667
    Altough this blaster served well enough, I wanted MORE sound. I started building this blaster in the summer in 2010, and though it has been in use several times, it is not yet finished.
    Drivers are Visaton BG 20. I chose them for their excellent sensitivity. Altough quite cheap, They offer real bang for the buck.
    Amplifier is amp6 Basic from 41Hz.com. Digital and offers 2x15 W.
    I chose lithium-ion batteries over NiMh or LiPo, since they are more carefree.
    These are trustfire 18650 2500mAh 3,7V cells and in series they produce 14,8V which is ideal for the amp6.
    The casing is 4mm plywood and fiberglass.
    The main music player is an old internet tablet Nokia N800. I also added an USB/SD-card player which works with a remote.
    And of course there is a plug for external players like cellphones.
    Some leather ornaments and guard for the driver.
    My original idea was to paint the blaster perly white with some car paint, but since I was in a hurry to get it ready, I used spray paint. On impulse I chose fluo yellow.
    It came out quite aggressive :D
    Same pictures but more story here in Allthemods.com
    Comments?
    Better color suggestions?
    mvagusta likes this.
  2. Jipa
    5 Feb 2004
    Easily my favorite blaster so far. Barely weights anything, looks nice and is loud enough.
  3. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Quite a brilliant build! Just one thing do you not feel the need to have more batteries?
  4. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    The metal guards look surprisingly good.
  5. willek
    19 Jan 2009
    Thanks! No need for more batteries.. These last playing for a day at full volume, and easily a weekend with medium volume. Though it would be easy to add another four in paraller if needed. There is yet space, and it wouldnt increase the weight too much.
    No they dont! :D They are temporary until I get the proper ones from lasercutting.
  6. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Awesome stuff :clap: :rock:
  7. willek
    19 Jan 2009
    Here are some pictures of the glass fibre phase.
    I dont know why I left them out in the first place :)
  8. willek
    19 Jan 2009
    Here are the new lasercut driver guards. They yet need to be brushed for better looks.
  9. HobbieZones.com
    HobbieZones.com What's a Dremel?
    13 Feb 2011
  10. BlobOfEvil
    BlobOfEvil Faux Wood Paneling is Fresh
    19 Oct 2010
    Hey, I really want to learn about how to make and mod electronics. I have access to some basic tools, because I'm friends with someone who fixes-up and mods motorcycles as a hobby. I also saved up about 85 dollars for a modding project of some kind, (which you have to remember is a large sum of money for a teenager).
    I decided that I wanted to start with building a really basic ghetto blaster. Would you guys help me with the electronic stuff?
  11. willek
    19 Jan 2009
    Old and new driver guard installed. Which is better? :)
  12. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    That's wicked- the new guards are definitely nicer :D
  13. pyro1son
    pyro1son Linux User!
    18 Aug 2010
    New one's look awesome!
  14. Javerh
    5 Sep 2006
    The old ones are juicy!
  15. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    This is an awesome thread. I came in here confused, saw the first picture and was intrigued, and then I see how you developed the idea fully and am quite amazed.
    It looks really great and it looks totally functional too. I've always wanted to get into fiberglass for projects like these with speakers. Very Nice.
  16. willek
    19 Jan 2009
    Years go by but I finally gave the blaster a decent clearcoat. I was afraid the clearcoat would reveal the bumpy surface on the fibreglass parts, but to my suprise the surface was clear and smooth, yay.
    I also upgraded the components a bit. The nokia n800 is gone. It was really useless in sunlight anyway and the battery ran out way before the blaster battery itself would.
    Now there is a pre-amplifier for the input jack. (most phones have weak outuput) Lastly a bigger aplifier (sure-electronics 2x50W) and a 6s lipo battery to go with that.
    All the images can be found here: http://www.lanita.org/~willek/temp/BiggerBlaster2010/
  17. SuicideNeil
    17 Aug 2009
    Ooh, upgrades. That really is a stunning piece of work, far nice to look at than anything a manufacturer has produced; that colour is just lush... :D
    Done anything else interesting lately?
