Displays Yet another monitor decision thread
Discussion in 'Hardware' started by adam_bagpuss, 17 Apr 2015.
  1. adam_bagpuss
    24 Apr 2009
    Hi all,
    so i did post a while back around what monitor to get but never ended up buying one as i haven't quite finished my office yet.
    I think i have the requirement nailed down now (he says)
    24-27" Screen size
    1080p (edited to help decision)
    under £350
    VESA supported as it will be wall mounted on a single ARM bracket.
    3D is not required
    My current GPU is AMD 7950 and i use a BenQ 21" 1080p 60hz TN screen
    Im open to IPS and 144hz TN as both provide a different kind of benefit. My only use is gaming really and the games vary. I do mainly play 4x or strategy games but do play FPS or action orientated games, Im not hardcore as i work for a living.
    Ive looked at freesync but its stupidly expensive for a 144hz TN panel and i dont like the 40hz minimum. I dont update my GPU often (2-3 years) so some games do dip below 40FPS.
    I like the look of IPS but is the lag really noticeable on FPS/action games ?
    thanks,
    Adam
  2. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    I was about to start a very similar thread, so I thought I would piggy back yours. I'll be using a GTX980 or a Titan. I'm considering the Acer Predator XB270HU as well as the usual Dells.
  3. JamesRC
    JamesRC Minimodder
    5 Oct 2012
    TBH I think you need to narrow down whether you'd like 1080p or 1440p or at least the preferred size (24 or 27"), otherwise there are too many options!
    Personally, I think 24" @ 1080p is still a sweet spot as it's not too pricey for dual or triple screens and you don't need mad GPU power to game. With a 7950, 1080p is easy but 1440p will be a struggle.
  4. SkiDave
    SkiDave Minimodder
    16 Mar 2008
    I've got a Dell U2412m (IPS) and haven't noticed any lag with FPS games (with a GTX970).
    Though I don't know how representative of IPS panels that is...
  5. adam_bagpuss
    24 Apr 2009
    thoughts on this screen
    Samsung 27 Inch LS27D590CS
    gets decent review is a Super VA panel - not too epensive either. slightly larger which is better for me and 1080p so dont need all that GPU horsepower
