Electronics Yet another question...
Discussion in 'Modding' started by Aurbo, 2 Jun 2005.
  1. Aurbo
    Aurbo What's a Dremel?
    26 May 2005
    Greetings again, one more question to pose.
    1 button triggers my playback circuits on 3 of my ISD voice recoder circuits.
    1 button triggers my playback circuits on 3 OTHER of my ISD voice circuits.
    All 6 voice circuits play into a set of speakers. ( hence the 2 question post earlier)
    Think English and French, one button plays 3 single play voice playback circuits for up to 2 min max in English, the second button plays for up to 2 min in French.
    A momentary trigger starts each of the ISD's so ganging 3 into 1 trigger button is what I am currently running.
    Pushing both buttons results in "Frenglish garble"
    How would I prevent one button from triggering the second set of 3 circuits while the first 3 are in play.
    Cheers
    Steve
  2. theshadow27
    theshadow27 What's a Dremel?
    23 Sep 2004
    is there an output comming off of the chips? like to drive a "playback" led?
  3. Aurbo
    26 May 2005
    unfortunatey no, each ISD circuit is independant of the others, the only common points are the common trigger/start button and the shared speakers.
    Steve
    *edit
    Let me check the manufacturer's file on these chips. The circuit I am currently using make no use of most of the chip features.
    *edit2
    nothing for output other than for speakers.
    Steve
  4. Aurbo
    26 May 2005
    I think I have solved this problem by using a spring loaded 2 position rocker switch,
    Rock to the left and you trigger the Reset on the French modules, and Play on the English.
    Rock to the right and you trigger the Reset on the English modules, and Play on the French.
    The reset stops the current language modules that are running, if no modules are running, it has no effect.
    Spring loaded returns the rocker to the center (neutral)
    I'll see if I can find this type of switch somewhere.
    Cheers
    Steve
