Modding Yet Another Vinyl Dye Post
Discussion in 'Modding' started by Wildmandingo, 25 Aug 2006.
  1. Wildmandingo
    Wildmandingo What's a Dremel?
    24 Jul 2006
    I know that everyone agrees that vinyl dye is the way to go. The problem is that I can find no product locally that claims to be "vinyl dye." Everything I can find says Vinyl Color, Vinyl Coating, or Vinyl Paint. Is there a certain brand I should be seeking out? Alot of forums, not this one, have posts claiming that Dupli-color Vinyl Color is indeed dye even tho it doesn't say dye anywhere on the can. The only brand I could find online that actually claims to be vinyl dye but its kinda high (SEM). Also, I'd like to find it locally so I can start dying as soon as possible.
    Every post I find on where to buy it says the same thing. "Check autoparts stores, Oreilly's, Autozone, and Lowes, etc." All I can find at these places is vinyl color and vinyl coating.
    Where in the U.S. can I get this and what brand should I be looking for?
    Thanks in advance
  2. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I think some clothing dies work for vinyl.
  3. customh
    customh conflagration.
    22 Oct 2005
    buuuzzz wrong answer. Anyways, i think rust oleum does a product called fusion, i saw it in wal mart and it looked interesting, says it bonds to plastics, as vinyl dye does, i believe.
  4. THEkorean
    THEkorean 42
    10 Jun 2005
    rustoleum is a great brand and their fusions are mainly meant for plastic, but i hear they do work on vinyl too, i personaly use Krylon fusion paints, they come in many diffrent colors and works on most surfaces (i am not sure so read the label) you can probably find them at your local HOme Depot, Lowes, general hardware store (i found mine at the corner hardware store)
  5. Wildmandingo
    24 Jul 2006
    I read the can for Krylon Fusion and it and it seems to coat the plastic just like normal spray paint. Vinyl dye is supposed to actually seep into the plastic rather than cover it up. I just found out that Sherwin-Williams carries SEM paint products so I will probably go by there and see if they may have it. Did the Krylon leave the texture of the plastic or did it cover it up?
  6. m0ng0lh0rde
    m0ng0lh0rde What's a Dremel?
    5 Jun 2004
    I used Krylon Fusion on my keyboard, and it did keep the texture of the plastic. Smotthed it out some, but you can still see it.
  7. hydro_electric_655
    13 Jul 2006
    Krylon fusion is a spray paint just made to donb more aggresively to plastic. There are vinyl dyes that dye the plastic not just paint over it. Looks much nicer.
  8. Quiglag
    Quiglag What's a Dremel?
    17 Sep 2003
    Check your local auto parts store, they have real vinyl dye spray cans, and just about everything else you need for modding, like bondo, fiberglass, sand paper, paint, etc.
