Relating to my current build here : http://forums.bit-tech.net/showthread.php?t=171054 3 options for the tubing ; Undecided as to whether ; A) Keep it white, as it is B) Use the braid over white tubing C) Use the braid over black tubing The braid is the same as has been used for all the wiring. Your thoughts and comments would be greatly appreciated. Cheers, Mark
If there is any UV in the case (sorry, I'm being a douche and not re-reading the log), then I vote for B. The UV will light up the white parts between the braid quite nicely Otherwise, C.
