Photos Your Room and Computer
Discussion in 'General' started by RTT, 19 Oct 2007.
  1. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    I think your opinion is wrong. I rather like it, in my opinion.
    btw, not a dig or anything :S
  2. Cabe6403
    Cabe6403 Supreme Commander
    3 Apr 2007
    I think swapping all the keys would be too much. This way its like the back of the lid. White apple in the center of a black background. This way its white keys in the center of a black background
  3. Matticus
    Matticus ...
    23 Feb 2008
    I think those white keys look the shizz.
    All of these awesome set ups make me want to purchase another monitor just so I can stand a small chance of running with the big boys of set ups.
  4. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
    Before
    After: Really bad quality taken from iPhone (No light)
  5. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
  6. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    looks like a comfy setup you have there. Might I ask what exactly that is above your keyboard, next to the scissors?
  7. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Looks like needlenose pliers to me :B
  8. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    It's the Saitek Eclipse, mouse is a g5, early Christmas presents :) much better then the Logitech EX100 wireless set up i was using.
    There is both scissors and pliers, the other part of my L desk is more of a work bench then a desk right now.
  9. K
    K 528491
    31 Oct 2001
    I rather like this. I've been thinking about doing something similar for some time with the wireless keyboard. I think it would look awesome with all black keys and a black vinyl dyed mighty mouse.
  10. Langer
    Langer Jesse Lang
    24 Jan 2004
    You'll encounter a big issue using macbook keys on your apple wireless keyboard mate.
    All of the numbers and qwerty keys on the macbook use clips that are positioned 90degrees where the clips on the apple wireless keyboard are 0degrees.
    See how the positioning of the little clips is different?
    What you'll end up with is this:
    What you'll then need to do is... take an xacto knife and trim down the existing white keys so they fit inside the black keys, you'll also have to cut the clips off the bottom of the black keys:
    The trimmed white key will fit right inside the black one:
    And you'll get this:
    repeat:
    BACK ON TOPIC:
    my desk right now:
    My workspace:
  11. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    now thats a work space!
  12. MrJay
    MrJay You are always where you want to be
    20 Sep 2008
    This is mine. my workspace is a total mess...have to look past that to appreciate its true beauty : P
  13. Cjshuck
    Cjshuck What's a Dremel?
    20 Dec 2008
    I only have a laptop at the moment and my desk is so messy I can't see half the keyboard. But I hope to get this PC Build (Me and my Uncle put it all together) and it will be awesome.
  14. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    Not really the place to post that but seeing as it's there I will stress that you SHOULD NOT buy that power supply. You get what you pay for with power supplies and £20 will get you ... rock all!
  15. Cjshuck
    20 Dec 2008
    I'm only a kid you know. This is costing me quite a bit of money.
  16. Matticus
    Matticus ...
    23 Feb 2008
    Spend another £30 or £40 on a power supply and you will save a ton of headaches (and probably money) in the long run.
    Trust us, the power supply is the most over specified in terms of wattage, and under specified in terms of quality.
    If you want to save a bit of cash, go for the normal, cheaper version of the 8600 and overclock it yourself.
    Have a look at scan as well, you can get corsair ram v cheap, and probably other bits too.
  17. Cjshuck
    20 Dec 2008
  18. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    wrong again :lol:
    For the PC you Specced in the list above, you will never ever need more then 300 Watt. Get a 350-400W supply from am A-brand, and you will have a lot less risk in your PC. It shouldn't cost more then 35-40 pounds i think...
    A-brands are:
    Tagan, P&PC Power and Cooling, Antec, Thermaltake, Corsair, Be Quiet, Enermax, Cooler Master and a few more i cant think of right now.
  19. Matticus
    Matticus ...
    23 Feb 2008
  20. Cjshuck
    20 Dec 2008
