Photos Your Room and Computer
Discussion in 'General' started by RTT, 19 Oct 2007.
  1. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Yeah, the case is VERY front heavy, it topples over if I don't! When I get back to uni it'll be fine..
    Sent from my A500 using Tapatalk
  2. Slazher
    Slazher What's a Dremel?
    12 Sep 2009
    Taken with an old camera, so the quality isnt that good.
  3. bagman
    bagman Minimodder
    18 Apr 2009
    Wow nice set up, I spy Bowers and Wilkins CM9. What amp are you using, and what headphones are they?
  4. Ficky Pucker
    Ficky Pucker I
    9 Jul 2009
    nice setup :) is that Sennheiser HD650 & Audio Gd NFB-10 ?
  5. Slazher
    12 Sep 2009
    Thanks :). Im using the Musical Fidelity a5.5. And Ficky Pucker is correct in both :)
    Im currently waiting for a Balanced cable from Ampcity for the Sennheisers so i can make full use of the Audio Gd.
  6. bigkingfun
    bigkingfun Tinkering addict
    27 Jul 2008
    Slazher that setup is über sweet. I am very jealous.
  7. Blazza181
    Blazza181 SVM PLACENTA CASEI
    19 Apr 2011
    Agreed.
    But can it play crysis?
  8. Slazher
    12 Sep 2009
    Thanks guys.
    How can i forget specs on a hardware site :duh:
    Intel core i7 2600k running at 4.4ghz
    Thermaltake Frio Cooler
    8gb gskill ripjaw
    Gigabyte GTX 570
    Intel SSD 510 series 120gb
    Samsung F3 1tb
    2x HP ZR24w 24" monitors
    Silverstone Fortress II
    Corsair HX750 PSU
    Im thinking about replacing the PSU and the cpu cooler, they are a bit too loud for my liking.
    Ive considered the Corsair AX850 PSU, im not so sure what to replace the Frio with. Any suggestions?
  9. dragontail
    dragontail 5bet Bluffer
    9 Jun 2005
    Thermalright Silver Arrow or the Noctua NH-D14. Why? See here. Both of them are super efficient and have outstanding cooling:noise ratio. I have my 2500K running at 4.6GHz 24/7, CPU idles at 28-30*C and both fans on my NH-D14 are spinning about 1000rpm (thought the 2500K does throttle to 1.6GHz when not under load so that explains the ridiculous temps).
    Also, if you can fit it inside your case, the Thermalright Archon is even better.
  10. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    Just built myself a new desk to replace the old dining room table that I was using before. Naturally, as I change stuff so frequently, the space intended to take my PC is too short to properly take the RV03, so on the desk it goes...
    Specs in sig...
  11. TrevDX
    TrevDX Ah Who Cares Anyway???
    9 Aug 2011
    My set-up....
    Still not too sure if I should be using my TV as a monitor :confused:
  12. Pookeyhead
    30 Jan 2004
    4:3 portrait cheesecake :)
    Good to see the 20" Dell in portrait is exactly the same height as a 30" screen. I have a 30" screen here but only 19" as the secondary, and it annoys me that it's slightly smaller. I'm watching a Dell 2001 screen on Ebay right now... may grab 2 of them actually :).
  13. Marvin-HHGTTG
    10 Oct 2010
    It is very nice I have to say. The panel is actually marginally larger, but it's not an issue, because the difference is only about 1-2mm at each end.
    I used to have two - one on each side, but TH2Go at that kind of resolution is a bit much on one 6950, and not that many games like playing at weird aspect ratios, so I sold the other, as I find it difficult to make use of two monitors for productivity purposes.
  14. dragontail
    9 Jun 2005
    Are the pixel densities similar or the same?
  15. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Only got iphone for photos, best desk I've ever had, nearly 10 years I think, is is actually a tidy state too
  16. Marvin-HHGTTG
    10 Oct 2010
    Similar enough to not make a noticeable/discernible difference. Both are 1600 pixels vertically now. As for physical size, only a mm or two in it.
    Holy image size batman!
  17. CDomville
    CDomville ^ I am THIS Possum
    4 Jan 2011
    Ideally you'd have a dedicated monitor, but I don't have the space, so I'm like you. the resolution HAS meant that I'm able to run games at higher settings fro a smoother frame rate, though.
  18. Pookeyhead
    30 Jan 2004
    Should be, as the horizontal res on the 20" is 1600, same as the vertical res of the 30".
    I thought the max res on TH2Go was 3840x1024?
  19. Marvin-HHGTTG
    10 Oct 2010
    Ah, sorry, that should read STH2Go.
  20. Cei
    Cei pew pew pew
    22 Mar 2008
    PC specs in sig, and the Mac is a 2009 Mac Pro (2.93Ghz Nehalem Quad, 8GB RAM, Vertex2 SSD etc). The MacBook Air is in my bag.
