Photos Your Room and Computer
Discussion in 'General' started by RTT, 19 Oct 2007.
  1. Mister_Tad
    27 Dec 2002
    Careful - I've done that before and over the years the blue leeched into/through the paper. It wasn't a big deal in my case as what was framed wasn't unique or notable, but this could be bad news in other circumstances.
    IanW likes this.
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Maybe make/install some mattes ?
  3. Byron C
    Byron C I was told there would be cheesecake…?
    12 Apr 2002
    Wot @Mister_Tad said - even a little bit of blu-tac over the long term is going to leach greasy stains through the paper. These aren't exactly expensive prints, but I'd still rather not ruin them.
    Yeah that would work. But TBH they're just cheap naff Ikea frames anyway; they're a total PITA to hang and the cardboard backing isn't held on with very much force. I do plan to replace them, as I've got an A1 print I need to hang downstairs - that one isn't a cheap print, so I want to find something a bit better than cheap Ikea stuff!
    IanW likes this.
  4. spolsh
    spolsh Multimodder
    4 Feb 2012
    perhaps a tiny dab of pritt* stick then ? It's pretty low tack but I suppose could still effect the paper some way.
    pritt stick has no connection to pritti patel of the spite girls, so it's not swearing
  5. Gareth Halfacree
    4 Dec 2007
    Nah, mount (matte) is the only way to go. Anything else and you'll live to regret it.
    bawjaws likes this.
  6. Vault-Tec
    30 Aug 2015
    Empty room. Spend three days deep cleaning said room and rearranging all the furniture. One nightmare later.
    sooo worth it.
    IanW and Goatee like this.
  7. spolsh
    spolsh Multimodder
    4 Feb 2012
    Empty the bin Mr V-T before it comes to life !!
  8. Vault-Tec
    30 Aug 2015
    I just bought a bigger one. Four cans and that one’s done.
  9. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Moved things around in the room and also switched around devices to better align with my wife's workflow (Novel planning, drafting and writing).
    My Desk -
    PC now in ITX format -
    Home Lab / Server peaking around the corner
    Wifey's Setup -
    Bonus - Server innards:
    (Squeezed in there is 7 x NVME drives, 4 x SATA SSD's and a single HD - not bad for a H510.... :p)
    adidan, Vault-Tec, IanW and 3 others like this.
  10. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Moved to the opposite wall of the office, away from the window and the thunderbug monitor threat........ aaaaannnnnd finally got to wall mounting the 43 inch screen, just to get it another 10 inches away from my eyeballs. Added bonus of lots more desk space!
    Spanky, SuperHans123, adidan and 2 others like this.
  11. Gareth Halfacree
    4 Dec 2007
    Poor quality photo 'cos I was using the terrible wide-angle lens on the phone, but here's the current state of play on my primary desk:
    Could do with switching keyboards to one of my shiny new ergo ones, but I'm waiting until I'm a bit less busy 'cos I know it'll slow me down for a bit. This works for now, though - still a big fan of the Q8 Alice, even if Keychron cheaped out on the plastic and the keycaps are showing shine already...
    Spanky, IanW, Byron C and 2 others like this.
  12. adidan
    25 Mar 2009
    I'm a simple man who asks simple questions: How u do dat 7 nvme fing?
    E: Ahh is that the Epyc uber guber board?
  13. xaser04
    27 Jun 2008
    Yarp! :grin: Super Micro H11-SSL-i with Eypc 7551P and 128GB of DDR4 RAM. Might move over to an Epyc 7542 (Zen 2 "Rome") for the better IPC and higher clocks if required and budget allows. May need more RAM as well but 128GB will do for now.
    1 x NVME on the board (for Hyper Visor OS install / because I could..:p:)
    4 x NVME on Asus M2 Adaptor card - Essentially going to be running in RAID 5 equivalent - "Fast" Storage Pool for Server
    2 x NVME (2230) on Seperate M2 Adaptor card - Running in RAID 1 (equivalent) for VM Boot Drive.
    The latter two I had spare from a Steam Deck Windows build and the original drive from my Ally.
    Normal SSD's are split with 2 x 512GB for the "Server" VM Boot drive (RAID 1 or equivalent) and 2 x 1GB for the "Slow" Storage pool. HD is in there for Backups only.
    In theory you can run the Asus card on a "normal" desktop board as long you have onboard graphics / can Bifurcate the primary PCI-e slot. However, in most cases, if you also want to run a GPU you are limited to x4/x4 on the Card thus two of the drives won't shows up. At least that is the case per the Asus documentation.
    I will say one thing, as someone who spends far to long cable managing the backside of a PC knowing it will annoy the crap out of me if I don't, dealing with the amount of Cables with this build was making my eye twitch!
    adidan likes this.
  14. M_D_K
    M_D_K Modder
    3 Apr 2002
    Just finished my new desk set up sort of, I might have another tidy up still need to find a place for my ipad.
    Piece of wallnut work top and made some chunky cantaliver stainless legs at work :), never again though weighs a ton without anything on it lol.
    Goatee, Spanky, IanW and 2 others like this.
  15. Gareth Halfacree
    4 Dec 2007
    Getting some twinges in my thumb, so I've finally got around to setting up the Glove80 ergo keyboard. Also using the vertical mouse, albeit temporarily - I really do prefer a trackball.
    It's not too much of a learning curve, as it's similar to my existing Maltron. It's definitely going to slow me down for a bit, though!
    IanW and Byron C like this.
  16. Mr_Mistoffelees
    26 Aug 2014
    Is it better built than the Maltron?
  17. Gareth Halfacree
    4 Dec 2007
    Oh, night and day - it's a much more solid design, takes up less room, and is actually adjustable! No good if you've got something against low-profile keycaps, tho'.
    Mr_Mistoffelees likes this.
  18. Mr_Mistoffelees
    26 Aug 2014
    I remembered you saying how poor quality the very costly Maltron was but, I don't need to change keyboards, I don't do enough typing.
    Can I pick your brains on trackballls though? I currently use a vertical mouse (Evoluent), because of problems with my right hand and wrist, caused by old cycling injuries. Do you know of a trackball that is held with the hand in the same orientation and, has a finger operated ball? Thumb operated is not good for me. Not sure I want to change but, would be good to try one out.
  19. Gareth Halfacree
    4 Dec 2007
    I know of them, but I've not tried one m'self. I *have* tried:
    What used to be called the Logitech Trackman Marble, and is now the "Logitech ERGO M575 Wireless Trackball Mouse." I'd been using a Trackman Marble since it came with a nine-pin serial connection, in fact, which is probably why my right thumb still gives me twinges every now and again. Which is why I moved to:
    The Kensington Orbit Scroll Ring, which uses your finger instead. It's... fine, I guess. Never loved it, though. So I then got one of these:
    The Kensington SlimBlade. Much better, and you spin the ball to scroll which is neat. Had one go dodgy on me, but Kensington replaced it (eventually - they sent an Orbit Scroll Ring by mistake first time around and it took an *age* To sort, but to apologise they let me spend some free credit in their web store. Picked up the monitor arm I'm still using now!)
    Neither of those are what you're after, tho'. There's the Kensington Pro Fit Ergo Vertical Wired Trackball, a name only a mother could love, but that's thumb-operated like the Logitech. The Kensington Orbit Fusion Wireless Trackball is finger-operated, but not vertical - just a little tilt. Even the presentation-oriented stuff is thumb operated.
    In fact, I can't find a single vertical trackball with finger operation. They're all thumb. Huh. Sorry, but looks like you've spotted a definite gap in the market!
  20. Mr_Mistoffelees
    26 Aug 2014
    The Logitech trackball, resembles one I used years ago, before the arthritis started to cause problems. I don't think thumb operation of the ball will work for me now. Will have to wait and see what comes along in the future. Thanks for your thoughts G.
    Gareth Halfacree likes this.
