YOUR VERTICAL GPU MOUNT IDEAS?
Discussion in 'Modding' started by mnpctech, 28 Jul 2017.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    iWalkingCorpse likes this.
  2. AtilaEKWB
    AtilaEKWB EKWB Representative
    29 Jul 2017
    Here is my home made vertical GPU bracket:
    customgtp likes this.
  3. mnpctech
    21 Apr 2003
    Clean work, good to see EK recruit another talented Modder!
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    Looks absolutely stunning! But, and I know it's not your fault, but that slightly offset pipe from the CPU to the GPU just breaks my heart a little.
  5. mnpctech
    21 Apr 2003
    it didnt bother me, looks fine.
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    If it helps, Linustechtips recently tried to see how far they could get a GPU from a mobo using extension leads. They managed about 3m / 9ft.
    mnpctech likes this.
  7. wst
    wst Minimodder
    30 Aug 2009
    What are the benefits to a vertical GPU installation in an upright case, other than aesthetic ones (and possible space efficiency with small cases)?
  8. Arboreal
    21 Jan 2011
    As long as the GPU is securely mounted in the case, having it vertical will be less of a strain on the mount.
    Horizontally mounted cars (motherboard vertical) are quite often seen sagging at the rear under the weight of the card and cooler.
    This will potentially strain the PCIe socket and motherboard, hence the recent addition of metal PCIE covers on some of the higher end motherboards.
    That said, the same would be true with heavy CPU coolers in a vertically mounted motherboard.
    I am in the process of swapping my ITX rig into an SG13, and one of the benefits there is the GPU is vertical, (less strain), and has access to cool outside air as it is next to the side of the case.
  9. mnpctech
    21 Apr 2003
    Arboreal likes this.
  10. Arboreal
    21 Jan 2011
    1.8Kg? Bill, that's a lot of cooling kit! No good for me and my SFF aspirations :eek:
  11. wst
    wst Minimodder
    30 Aug 2009
    That's heavier than my CPU cooler (a shade over 1kg), and that was fortunate enough to come with extra bracing. The poor PCI-e slot that has to deal with 1.8kg.
    I've also just realised what the vertical slot is on the back of my case as well. It'd only fit a single slot backplate though, unfortunately.
  12. mnpctech
    21 Apr 2003
    Are you familiar with the NCASE? I'm experimenting with a vertical GPU mount design. It will limit your choice of Heatsink / Fan Combos to models under 70mm tall, but will present new layout scenarios for DIY liquid cooling.
    Yesterday I had the thought of making a micro reservoir to mount on the bracket alongside the GPU, but that presents challenge of where to mount a pump?
    MLyons and Arboreal like this.
  13. mnpctech
    21 Apr 2003
  14. BU5H W00K1E
    BU5H W00K1E Minimodder
    18 Nov 2017
    That case and the mount make me wanna do a small form factor water cooling build! But sadly i just finished VUE 71, and i'm designing a scratch build next. Will have to get one of your vertical gpu mounts tho for the scratch build.
  15. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I cheated, and bought a mATX cube case, so the motherboard sits horizontally.
  16. mnpctech
    21 Apr 2003
    @I&W, lemme guess, CaseLabs or Lian Li? and I've noticed the influx of new cases by several manus with vertical mounts now.
    @BU5H W00K1E, mention post when ready, we may have voucher code for discount, https://mnpctech.com/contact-us.html
  17. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Nope. Thermaltake Core V21. Very happy with it.
  18. mnpctech
    21 Apr 2003
    Ok, those are very unique design.
    Carlos Fractal design Nano S with Vertical GPU looks good!
  19. mnpctech
    21 Apr 2003
  20. BU5H W00K1E
    18 Nov 2017
    Might have to pic one up for a future build I’m planning
