Other Yup Chairs. £60
Discussion in 'Hardware' started by Jaybles, 12 Nov 2012.
  1. Jaybles
    Jaybles New Member
    12 Feb 2011
    My current desk chair has casters that fall off and then when I try to move I fall off. Soooo I need a new chair. What can I get for £60? Or push it to £70.
    Ta
  2. GeorgeStorm
    16 Dec 2008
    I'm currently using an IKEA Verner I believe, seems to have been discontinued, but I like it, can adjust the height, not the angle of the back though.
    Cost me £50 I think.
    I'd recommend something from IKEA, especially if you can go to one and try them out.
  3. Harlequin
    Harlequin Well-Known Member
    4 Jun 2004
    staples have some nice bargains rotating around the discount sales
  4. j4mi3
    j4mi3 New Member
    28 Jun 2011
    I despise that establishment
  5. Jaybles
    Jaybles New Member
    12 Feb 2011
    Whys this?
  6. megadriveguy
    megadriveguy Active Member
    19 May 2010
    I have found Ebay to be the best place for office chairs, some surprisingly good quality chairs for the prices, and there should be some nice ones around your price range including delivery
  7. MSHunter
    MSHunter Well-Known Member
    24 Apr 2009
    Love the IKA chairs with the fabric "net" backing lets your back breath (sweat less).
  8. Guest-23315
    Guest-23315 Guest
    I found Staples to be very good actually. Just go in and try them out... failing that, I've seen some pretty nice ones in charity shops for an absolute steal.
  9. Jaybles
    Jaybles New Member
    12 Feb 2011
  10. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    That's what I've got.
    Great chair, has lasted much better than the cheap rubbish I had before it.
    Think its about £90 though, or was when I got mine.
  11. Jaybles
    Jaybles New Member
    12 Feb 2011
    Have you got a link to it?
  12. ShinyAli
    ShinyAli New Member
    14 Sep 2012
    I can't recommend a chair as the last one I bought from ebay cost £120 and was absolute crap but I just wanted to say that if you care about your sitting posture when at your desk then make sure the arm rests come up to or near the level of your desk top so your arms are level with the desk when working this helps to keep your back straight.
    I bought a new desk which was described as a computer desk but it is too high and my old chair was too low to sit comfortably at it so I then had to get a new chair which had a high enough seat and arm rests but then when the seat was high enough for the desk my feet were barely touching the floor so I then had to get a proper foot rest to support my feet, geez, if it hadn't cost about £250 for it all it would be laughable, actually it is still laughable :D:D
    Anyway, moral is, don't buy an office desk to use as a computer desk as they are often too high :rolleyes:
  13. Carrie
    Carrie Well-Known Member
    18 Nov 2010
    Why not try gluing the casters on with a serious heavy duty mastic ?
  14. bagman
    bagman Well-Known Member
    18 Apr 2009
    Epoxy
  15. Carrie
    18 Nov 2010
    Either would do. And it'd be a lot cheaper than buying a new chair
  16. Jaybles
    Jaybles New Member
    12 Feb 2011
    It's a ***** chair anyway. Twas free and is really uncomfortable. And it doesn't have armrests. Or tilt.
  17. Jasio
    Jasio Made in Canada
    27 Jun 2008
  18. terrorbyt
    terrorbyt MultiModder
    19 Apr 2012
    Do you work for Dunder Miflin?
  19. Jaybles
    Jaybles New Member
    12 Feb 2011
    After much thought I think I will go for this.
    Anything else i should think about before I purchase. Jasio that is a nice chair but almost double what I initially wanted to spend.
  20. Harlequin
    4 Jun 2004
