"Yuugou" Finished (1 Buy.com Lan pic)
Discussion in 'Project Logs' started by greensabbath, 23 Mar 2006.
  1. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    can you fade CCFLs?
    i would think they'd have to be an array of LEDs.
  2. khendar
    khendar What's a Dremel?
    25 May 2004
    You can, though its probably not good for them. I have a 3.5" drive bay which can fade CCFL's on and off. They don't fade in brightness, they actually fade from the ends, with more of the tube being lit up as it fades in.
  3. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Greeny: Really good-stuff..!!
  4. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    Thanks very much guys. The case is at powder coating right now so there isn't much to do. Actually I won't be showing the powder coated case until its release date in late March or April. Until then, I have some wood working to do and one last update on the aluminum.
    Here is what i did (and almost totally forgot about) before I dropped the case off at the powder coaters.
    I needed to find an elegant way to get the tubing through the mesh:
    So I started by doing this:
    That looked kind of weird so I decided to make a backer for it:
    I cut this on my scroll saw out of .09 inch aluminum:
    And J-B Welded to the mesh:
    This should be hot once its powder coated.
    Until next time, stay tuned.
    Oh I almost forgot, check the New York Times business section on March 18th, there should be something special. :D
  5. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    wow, that is just a little touch that really looks good! we dont get the times here, and i am still curious about what it is.
  6. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    hey its those little touches that make this mod brilliant, keep it up!
  7. randosome
    randosome Banned
    17 Sep 2006
    wow that makes a really cool effect :D
  8. ComputerKing
    8 Sep 2006
    that's what I love to see :D keep it up !!
  9. greensabbath
    19 Apr 2005
    Thanks guys.
    Don't worry if you don't get it, I'll probably be posting a PDF of it too... Still can't say what it is though, but its very cool.
  10. greensabbath
    19 Apr 2005
    I have some good news guys, Corsair is now officially my second sponsor. They'll be giving me a set of their Dominator 6400C4D memory with the fans. I sense a bit of modding will need to be done with those fans as well :D
    In other news, i've been working on a bunch of random things. I've been finishing up the wood, I have some more metal work to do, and i've been painting fans but for the most part, i've been taking a little break. Not to worry though, things should heat up next week, stay tuned.
  11. itsjustacompaq
    7 Sep 2006
    thats awesome dude! i just got one of their memory coolers a couple weeks ago and it looks incredibly trick. i will be polishing the face and putting LED's behind it. im eager to see what you do with it, maybe a veneer on the front?
  12. Damouse
    Damouse Thats no moon!
    27 Jan 2007
    very nice stuff. Did you have to beg them to come or did they come arunnin
  13. greensabbath
    19 Apr 2005
    @itsjustacompaq: I'm not totally sure but I do have a lot of veneers and that might be in order :D we shall see
    @Damouse: They definitely seemed eager. They sponsor a lot of modders actually but I can't really take the credit for snagging this one.
  14. Nix
    Nix What's a Dremel?
    22 Nov 2005
    Where did you get the mesh from. I like the design of it.
  15. greensabbath
    19 Apr 2005
    I like it too. I got it from Mcmaster.com Part number 9344T55
  16. elliod
    elliod What's a Dremel?
    1 Oct 2006
    WOW man really nice work i'd say .
    keep up the good work man
  17. sparkyftw
    sparkyftw What's a Dremel?
    10 Nov 2006
    good thing this case is at powdercoating, I have time to mod cause I am not stuck to the screen drooling.
    time to grab my dremel and take some pics of my progress
  18. tkdwarrior
    tkdwarrior What's a Dremel?
    5 Jul 2006
    congrats on the sponsor! :D
    wonder who helped you out..
  19. wbdog206
    wbdog206 not me
    15 Jan 2007
    this case looks great
  20. Tale Gunner
    Tale Gunner What's a Dremel?
    15 Dec 2006
    Greensabbath you are an artist. No doubt :D Im watching your every move!
