Motherboards Z170 miTX boards
Discussion in 'Hardware' started by silk186, 13 Jun 2015.
  1. silk186
    silk186 Derp
    1 Dec 2014
  2. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    So far only Gigabyte seems to be taking full advantage of the chipset features. Any board that lacks m.2 and the usb 3.1/Thunderbolt C connector would be a non starter in my opinion. I do wish they would all dump sata express in favor of the u.2 (SFF-8639) as it is clearly the winner there.
    Personally I will be waiting for Skylake-E before I make any choices about upgrading... also super excited to see how the new DDR4 hybrid nvdimm does though I fear the prices.
  3. silk186
    silk186 Derp
    1 Dec 2014
    I really don't understand what sata express is included. I don't even know of any sata express drives. With the Z170 chipset all boards should have M.2 as their is no shortage of lanes, especially with mITX boards. Skylake-E is above my budget unfortunately...
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    The ASRock also has M.2 (presumably on the rear of the board too), and lists a pair of USB 3.1 Type A connectors (to Gigabyte's single Type C). It's a real pain that high density Type C blocks don't seem to be readily available yet, so you have motherboards with the ludicrous inclusion of single Type C connectors in the space where you could fit two Type As.
    The good news is no boards so far have the CPU socket placed right next to the PCI-E slot, so no fitment issues with larger top-flow heatsinks.
  5. silk186
    silk186 Derp
    1 Dec 2014
    So far the boards are looking good, though choices are few. I only really need 1 usb 3.1 port and a few 3.0. Most devices are still 2.0
  6. zedshead
    zedshead What's a Dremel?
    4 Apr 2015
    Goog performance and good quality...
  7. silk186
    silk186 Derp
    1 Dec 2014
    New board: Z170 Stinger
  8. Icelander
    Icelander Minimodder
    3 Mar 2015
    Like that EVGA one a lot
  9. img
    img Minimodder
    23 Oct 2001
    Glad designs are looking better when my 2500k dies. Love my sg05 considering how much I van fit in it
  10. silk186
    silk186 Derp
    1 Dec 2014
    the EVGA looks nice but I don't like the SATA placement.
  11. edzieba
    14 Jan 2009
    The EVGA sadly does not have support for m.2 SSDs; that m.2 port attaches to a riser that points straight up out of the board, intended only for WiFi modules..
  12. Taua
    Taua What's a Dremel?
    20 Sep 2014
    SATA express is not needed, m2 should be on the front side, those things run hot. All those listed (ty for doing so) look quite middling.
    The Asus Impact VII is a beast of an ITX board, the Z170 Impact will probably end up being the top dog...uhm, mouse? of the ITX FF again.
  13. silk186
    silk186 Derp
    1 Dec 2014
    But no word on it yet. I'm not sure if that's normal.
