Hardware Z97 Close Up: Gigabyte and Asus ROG boards
Discussion in 'Article Discussion' started by Dogbert666, 2 May 2014.
  1. faugusztin
    11 Aug 2008
    I don't even mind some boards not having SATA Express... What i am starting to be totally annoyed with is Intel and their limited PCIe lanes. Take ANY Z97 board from ASUS, and you will find stuff like :
    So you got an physical x16/electrical x4 slot, but you need to take care not to use it for anything else than x1 card, otherwise you will lose the M.2 and another PCI-E slot. I had a similar issue on the Z77 board, where i could use two PCI-E x1 devices, one PCI-E x4 device or the additional SATA3 controller, but not all 3 of them. :wallbash:
    Intel, in the next generation of consumer CPU add at least another 5-10 PCI-E lanes, pretty please :D.
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    From my limited understanding X79 (LGA 2011) and upwards have 40 lanes available, but how the board manufacture divides those up between the different slots and/or devices can differ a great deal.
    EDIT: The extra pins on LGA 2011 are used for the extra lanes.
    And AFAIK the rest have 16 lanes, although I'm none to sure on that :confused:
  3. faugusztin
    11 Aug 2008
    Sure, S2011 has more PCI-E lanes... But on other side doesn't have IGP, which is important to a typical user too.
    My point was that the current amount PCI-E lanes on S115x are slowly becoming a problem even for board manufacturers, because there are simply not enough for them even for their own onboard chips.
    @jrs77: on other side it will make them an ideal solution for coolers like NH-L12.
  4. Corky42
    30 Oct 2012
    Yea i totally agree the 16 lanes are becoming a problem, one that doesn't seem to be going away until Intel transition the non enthusiast chips/sockets to higher pin counts.
  5. SchizoFrog
    SchizoFrog New Member
    5 May 2009
    Maybe I am in error but if the cooler can clear RAM modules I am pretty certain it can clear SATA cables?
  6. captain caveman
    captain caveman life is pain
    14 May 2010
    interesting point your making, my understanding was that sata express was going to give a considerable speed hike
Tags: Add Tags
