News Zalman FX100 Cube passive heatsink leaks
Discussion in 'Article Discussion' started by Gareth Halfacree, 14 Nov 2012.
  1. Gareth Halfacree
    4 Dec 2007
  2. yuusou
    yuusou Multimodder
    5 Nov 2006
    That title was a bit misleading. I thought it was a water-cooling system that leaked for some reason.
  3. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Convection maybe?
    Looks interesting, I'm wondering how they'll achieve a high enough airflow passively to cool higher-end CPUs.
  4. Gareth Halfacree
    4 Dec 2007
    Eerr, quite. Fixed, ta!
  5. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    i was confused by the title too.
    FanlessTech, that is a cool website some really cool products posted there.
  6. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    these modern spell checkers that change correctly spelt words are a bitch, lol ;-)
  7. Deders
    Deders Modder
    14 Nov 2010
    What happens to the convection when it's put on it's side like in most cases?
  8. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Presumably referring to the gas/liquid in the heat pipes with a very low boiling point (not [greatly] affected by gravity).
  9. GeorgeK
    18 Sep 2010
    Looks like you're strapping a fridge to your CPU...
  10. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    for something that's supposed to rely on passive airflow, why the hell did they block off a significant portion of their air-path?
  11. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    That's why I prefer the Nofan CR-95 (also available in pure copper)
  12. Guinevere
    Guinevere Mega Mom
    8 May 2010
    I don't think they did. I think the 'corner pieces' are there to make it all rigid and appear to maybe to route the heatpipes though?
    If anyone call pull this off it's Zalman. Their passive heatpipe cases were state of the art (at the time) and I have a heatpipe cooled PSU of theirs that's been going strong (and cool) for many a moon.
  13. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Because of the same way a chimney works maybe ?, pulling cool air in at the bottom and extracting it at the top
  14. AiA
    AiA Minimodder
    25 Jul 2009
  15. Bakes
    Bakes What's a Dremel?
    4 Jun 2010
    'Impressive performance'? By that I hope you mean 'cools the cpu to a level where it won't blow up on stock settings'. Seriously. If they can manage that passively, then that's impressive enough for me.
  16. greigaitken
    greigaitken Minimodder
    26 Aug 2009
    bous air cooling from back of motherboard as it bends like crazy
  17. greigaitken
    26 Aug 2009
  18. fluxtatic
    fluxtatic What's a Dremel?
    25 Aug 2010
    I'm no thermal engineer, but like Deders said, how the hell is this supposed to work via convection when it will be sideways in the typical case? Ah, well, I'll wait for the reviews.
    Also, keep in mind the TDP of Ivy Bridge tops out at 77W. This might work brilliantly for those and even SB @ 95W. You might want to avoid sticking it on your AMD FX-8350, though ;)
  19. Skippylee
    Skippylee Now then!
    12 Feb 2010
