Hardware Zalman GS1000
Discussion in 'Article Discussion' started by Guest-16, 9 Jul 2008.
  1. Guest-16
    Guest-16 Guest
    http://www.bit-tech.net/hardware/2008/07/09/zalman-gs1000/1
    Zalman, long a staple of the ultra high-end case market, tries it's hand at a case aimed firmly at the mid range, with the GS1000. Sporting some impressive features, we investigate to see whether the GS1000 can compete in the most competitive of price ranges.
  2. Guest-23315
    Guest-23315 Guest
    Why not implicate a bottom mounted 120mm fan for the HDD's.
    It seems silly not cooling the HDD's at all.
  3. Naberius
    Naberius What's a Dremel?
    20 Nov 2006
    It seem so silly designing a case to look like that.
  4. DeSean
    DeSean What's a Dremel?
    22 Oct 2006
    I believe there was a Google study recently that showed hard drive life to be fairly unaffected by temperature. I do agree that cooler drives are usually preferable though. I really like the hot-swap idea, even if its only used for fast hard drive changes whilst the system is off. I love my Silverstone TJ-09 but it is a huge pain to organise all the cables going to the hard drives. I don't know why these companies don't mix all the best features together into one case!
  5. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    I think that kind of person would go for a CMS 830 with 2 5in3 drive swap bays anyway. thats 10 drives with 2 slots left for optical and cardreader.
    classic engineering flop, the details are the killer
  6. Guest-23315
    Guest-23315 Guest
    For Hot swappers, why not that nify Li-Li?
  7. ParaHelix.org
    ParaHelix.org What's a Dremel?
    19 Jun 2008
    Well, looks like I will be sticking with good old Lian-Li thanks.
  8. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Eh... I don't like it. Tacky plastic and classy aluminum combined into one mediocre box.
  9. ssj12
    ssj12 Minimodder
    12 Sep 2007
    ugly case.. I'll stick with my NZXT cases thanks.
  10. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    This thing is absolutely hideous. Far better cases exist in the same price range. Zalman should stick to what they know: Cooling.
    And to note as said above; it's pretty odd that a company known primarily for their cooling products would neglect to provide any form of heat relief for the HDD's. Party foul Zalman. Party foul.
  11. Multiplectic
    Multiplectic His Stigness
    4 Sep 2007
    Uummm... This case is utterly UGLY. The exterior design is completely rubbish.
    And though thermal performance is pretty good, there's no cooling for the HDDs (many people, like me, DO care about that).
    Plus, I've never been a fan of bottom mounted PSUs. If it's cables are not long enough, you've had it.
  12. Amon
    Amon inch-perfect
    1 Jun 2007
    Looks incredibly sturdy. For some, it may be all that matters, particularly in this range of product price and, proportionally, what's inside.
  13. Cadillac Ferd
    Cadillac Ferd What's a Dremel?
    11 Oct 2005
    Meh, looks pretty fugly. I'm really not a big fan of mixing metal and plastic, it makes the plastic look even tackier.
    Also did I miss something about Zalman? Since when have they been considered the BMW of computer peripherals? I mean from my experience their products are alright but really not all that special or anything.
  14. Jonagon
    Jonagon What's a Dremel?
    25 Feb 2007
    "However, the reset button and HDD activity LED are notable by their complete absence - we still like to see these inclusions on a case; I know I still use mine at least a few times a week."
    You do? Personally, I can't remember the last time I used either..
    Yeah.. as others have said, it's not a case i'll be looking into buying, though I am after a case in that price bracket.
  15. naokaji
    naokaji whatever
    8 Dec 2006
    a case for more than 100£ shoudnt have a plastic exterior.
    the zalman fans arent bad, they preform well and are very cheap, but if you have several it can indeed get noisy.
  16. kenco_uk
    28 Nov 2003
    I'm not sure I'd miss a reset button, but I'd definately miss a hdd indicator light. What concerns me more is the ability to drag the weight of a loaded system from under your desk to upgrade/repair stuff. Why not have castors? Or the sledge arrangement that the Cosmos sits on? As for the build quality - that's a real put-off. Was this a retail unit you reviewed?
  17. Baz
    Baz I work for Corsair
    13 Jan 2005
    Keep your eyes on bit-tech - I've got the Akasa Omega and Lian Li PC X2000 ready for review - both cases show a LOT of promise.
  18. wyx087
    wyx087 Multimodder
    15 Aug 2007
    surpricingly, i hit reset button more than my power button..... HDD light can be dismissed without problem, same goes for the power LED. both are redundent LED where you will only look at if your monitor is off or not responding.
    is it me or every case manufacturer is copying Antec's design? (was it antec's orignal idea to put PSU on the bottom? )
  19. AlexB
    AlexB Web Nerd
    22 Dec 2005
    Nice looking case.
    Haven't used my reset button in about 5 years.
  20. Cupboard
    Cupboard I'm not a modder.
    30 Jan 2007
    I do use the reset button quite a bit. I find it helpful when I have missed getting onto the BIOS when I am starting my computer up, and similar such scenarios. My motherboard actually records how many times it has been pressed, I will have a look next time I restart it.
    As for the case - oh well. Thanks for the review though :)
    Still looking for something similar to the case that was used in the £400 PC build, cheap and not too rubbish.
Tags: Add Tags
