News Zalman makes watercooled case, LQ1000
Discussion in 'Article Discussion' started by Da Dego, 11 Jun 2007.
  1. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Link points to the forum itself, not to this thread. :)
    [ontopic]
    Looking good but it'll be expensive just like the SilverStone one...
    And I think the BT community wouldn't buy pre-watercooled cases, right? ;)
  3. ./^\.Ace./^\.
    ./^\.Ace./^\. What's a Dremel?
    7 Jun 2007
    It makes sence to make a case like this one after there heatpipe cases :clap: I have one problem with tha case though :nono: if you look at the front there are only 3x 5.25" and only 1x 3.5" drive bay. I don't know about you but i have more stuff in the front of my PC then that :duh:
  4. airchie
    airchie What's a Dremel?
    22 Mar 2005
    That looks totally sweet IMO!
    Any word on what kinda pump is in it?
  5. Guest-16
    Guest-16 Guest
    Nothing, sorry. It was a technical demonstration and I was literally just shooting through the booth on my way elsewhere when I noticed it.
  6. Hazchem
    Hazchem Minimodder
    3 Dec 2004
    I love the side panel idea, but the dials on the front could look better I think, tasty case though!
  7. Anakha
    Anakha Minimodder
    6 Sep 2002
    TBH, I think that side rad could be a lot more dense. From the looks of it, it only passes across the side panel 3 times, with a lot of space for turning. That could easily be tightened, giving more heat transfer.
  8. Colossous
    Colossous Minimodder
    28 May 2007
    I cant see it being for the high performance water people tbh ?!! :eyebrow:
  9. Guest-16
    Guest-16 Guest
    It's not. It's for cooling with silence.
  10. trig
    trig god's little mistake
    10 Aug 2006
    did anyone else notice it uses both sides of the case to passively cool? nice.
  11. Buzzons
    Buzzons Minimodder
    21 Jul 2005
    ai that is damn nice :)
  12. samkiller42
    25 Apr 2006
    That is a nice looking case, although, its not as nice as a Lian li :thumb:
    Sam
  13. Bachy
    Bachy What's a Dremel?
    27 Sep 2002
    Nice, very nice
    I want this now! dont care how much it costs - it will be mine :D
  14. ./^\.Ace./^\.
    7 Jun 2007
    Shure you get the cooling built right in but you lose any chance of having a window in the case and look at the front, there are like no drive bays. I need at least 4x 5.25" and 1x 3.5". even then if I wanted a LCD display infront then I would need 5x 5.25" drive bays.
  15. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    what? there are 3 drive bays... i only ever need two - what the hell do you need four for?
    you can get LCDs that take up only 2 Drive bays, i'd hate to see what kinda LCD needs 5.
    and windows are pointless :p
  16. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    I wonder if they include the blocks
  17. pendragon
    pendragon I pickle they
    14 May 2004
    wow... that's an impressive case! looks awesome too!
  18. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    ooooooo thats very nice!
    i want one
  19. trig
    10 Aug 2006
    and if so, what blocks are they?
  20. Andune
    Andune What's a Dremel?
    9 Jan 2007
    Hmm if they only could have hidden that 120mm radiator in the back inside the case it would look so much better. Dont like the lower part of the front either, otherwise it looks great.
Tags: Add Tags
