I need some help. I have bought a nice zalman multi fan speed controller. The ZM-MFC 1. This conroller has a blue plastic cover. I have a nice lian li case and I want to mod a bezel so I have it in style with my case. To drill the holes and mount the controller won't be a problem but I want to print the insructions on the silver bezel. Does anyone has a guide or link on how to do that. Have seen it in some worklog but can't find it anymore.
laser engraving would probably work well. Are you in or near a big city? Around here I would call a shop that sells trophys and awards and ask them to do it for me. good luck.
I also tought of those iron on sheets fore use on t shirts. Would that work?! Because that would be quet simple.!
Id go to a professional place, i happen to know someone that worked at a laser shop, so i know where one is, and thats what i would go with. Looks spiffy.
Use a sharpy to color the front black put paper behind it scan it. Print it out. Get some contact adhesive in a spray can spray both surfaces rough cut everything then hand file to perfection using the black body as a guide.
