Hardware Zalman ZMachine LQ1000
Discussion in 'Article Discussion' started by Guest-16, 19 Sep 2008.
  1. Guest-16
    Guest-16 Guest
    http://www.bit-tech.net/hardware/2008/09/19/zalman-lq1000/1
    Today we take a look at the Zalman ZMachine LQ1000 , an ultra premium case with in-built water-cooling boasting high end performance, but with a high price to match. Does the LQ1000 float our boat, or is it just a wet weekend? We don the bit-tech scuba gear and find out!
    :brrr:
  2. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I saw this case a while back. £400 is quite a lot to pay but I guess you get a £200 case and a £200 WC setup.
  3. The boy 4rm oz
    10 Apr 2008
    For what you pay for it it better perform well lol. I would still rather an NZXT Kaos with a custom water loop.
  4. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Why not included chipset and/or videocard into the loop. On my own WC rig its a pre running a 240 rad for chipset and cpu and a 120 rad on the vidcard (from aqua-computer). With the 120mm fans being noctua's and the pump a Eheim. Its absolutely silence. The 4 samsung HD's in my system make more noise.
  5. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    it doesnt cool the gpu, but then you might be able to add that later, although their pump might not push enough water through to cool both of them, hmmmmmmmmmm
  6. ChaosDefinesOrder
    ChaosDefinesOrder Vapourmodder
    6 Feb 2008
    I'd be interested to see what the performance is like when a high powered graphics card is added to the loop - do you guys have a BFG GTX 280 WC knocking around at all?
    Any chance of an addendum to include something like this?
  7. Baz
    Baz I work for Corsair
    13 Jan 2005
    The manual says that the loop will happily cope with cooling a graphics card too, and you get more than enough spare tubing to accommodate this. Sorry for not mentioning this in the review, although switching the GFX card would have made our GPU stress test results somewhat meaningless.
  8. mrb_no1
    mrb_no1 Pie Eater
    15 Sep 2007
    oh nice to hear, thanks for adding that Baz, although it might have been nice to see how good the loop is with a 4800 or 280 as they are the biggest single card power draws so it would really test the loop and see of proficient it is at cooling. off for a run,
    peace
    fatman
  9. badders
    badders Neuken in de Keuken
    4 Dec 2007
    This is true, but then this case doesn't really directly compare to the other air-cooled cases that are tested in the same way.
    BTW, I never grasped the scale of the Asus Silent square pro until my friend got one for his P4 setup the othe day - it fills the rest of the space in his case!
  10. karx11erx
    karx11erx What's a Dremel?
    17 Dec 2004
    What's the point of using water cooling if you do not include at the least gfx card (and probably the HDs) in the cooling loop? If you want a silent system, that would be a must.
  11. [USRF]Obiwan
    9 Apr 2003
    When can we expect the new Antec in the bt office?
  12. Baz
    13 Jan 2005
    test bench +desk fan = done! ;)
    Seriously though, we've requested it, it shouldn't be too long.
  13. Goty
    Goty Minimodder
    13 Dec 2005
    I definitely wouldn't try adding a video card to that loop with the pump pushing less than a liter per hour through the loop. My absolute lower limit on flow in my loop is somewhere around 3 liters per hour. Add in the fact that most video card blocks are quite restrictive on top of the sheer heat load a video card would add into the loop and you'll see that it wouldn't be in your best interest to try adding a GPU waterblock.
  14. naokaji
    naokaji whatever
    8 Dec 2006
    The cooling performance is rather poor, 3C difference in cpu temp to the hyper osiris when idle and 4c under load, plus the gpu running hotter than a whole range of "normal" cases and that for 400£... sorry, but I'll have to call it a failure.
  15. Guest-16
    Guest-16 Guest
    You're not taking into account noise difference which is massive between any aircooled case on high and this on low. Plus, with respectively less airflow through the case the passively cooler graphics card is bound to heat up. Zalman designs its products to be the right balance between noise and cooling, and this works very well to achieve this.
  16. Broken Dwarf
    Broken Dwarf o rly?
    19 Sep 2008
    There's one bit I don't really like : "four terabytes of storage (or soon more) – more than most will ever need.". Err... what?
    Aparently we'll be all dead in 5 years if Moore's law is to be believed( on the basis that we won't "ever" need more than 4 TB of storage OR more than 4 drive bays.) You can't assume we won't use more than 4 drives. What about RAID 50 / 60? This is bananas!
  17. Otto69
    Otto69 What's a Dremel?
    6 Oct 2007
    Again Zalman uses the fin and tube style radiator. Why don't they use the more efficient automotive style radiator?
    The thick aluminum is nice, but I'd rather have a better radiator and quieter fans.
  18. Boogle
    Boogle What's a Dremel?
    8 Mar 2002
    To be honest, given the price I'd rather get a Koolance Lian Li case. Vastly superior cooling, for only a little more outlay. Plus the Lian Li cases are more spacious albeit at the expense of super-thick paneling.
  19. Guest-16
    Guest-16 Guest
    He meant right now, that's why it had in brackets "(or more soon)" - in time hard drive density will grow allowing bigger capacities, but without additional cooling I wouldn't want to cram more than four in to be honest.
  20. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    very sweet case.
    unacceptable price though.
    but thats just me and my poor wallet.
Tags: Add Tags
