Scratch Build – In Progress Zanettii's Carputer Project
Discussion in 'Project Logs' started by zanettii, 20 Oct 2009.
  1. FrooP
    FrooP can I eat this?
    24 Oct 2007
    no because you should watch the traffic while driving :nono:
  2. zanettii
    zanettii What's a Dremel?
    11 Dec 2008
    Hehe, but it would have been nice just for show! Maybe i'll intergrate my old gamecube? :eeek: hehe
  3. zanettii
    11 Dec 2008
    NOW guys, made alot of progress now.
    The right sidepanel is done, built with a small "door" in it. This is because i need to get access to my rear-lights, and a nice way to hide some car polish and tools!
    The sidepanel is packed with some leather, and i mounted a nice handle who originally is mountet in the trunk, to open and close the door.
    The floor panels is packed with leather.
    Ive started to make the left sidepanel, who will house the carputer, also started to build the casing for the carputer, but i'm waiting for my new ITX mobo, so i cant finish it yet.
    All cables for amps and speakers are connected, and it works nicley.
    Want some pictures?
    Have some really crappy ones, will get back with some real quality soon.
    Right side-panel made
    With a handy door to get access to the back.
    Some wood-blocks to lock the panel in place.
    Mounted in the car.
    With some leather
    Beauty?
    The back is a mess, but i will glue on a leather piece to hide the staples and such.
    Mounted in the car. i like it!
    Now the floor panel with leather covering
    Subwoofer enclosure mounted inside
    Right frontpanel mounted
    Some of todays work!
    Some woofers needs to be mounted
    Sweet combination with the leather-black woofer
    Some iphone suckass quality pictures, but with better lights though.
    What do you think guys?
    More updates to come, when my mobo arrives!
  4. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    This is your third car and the computer isn't done yet.....That's not right.:eyebrow:
  5. Stickeh
    Stickeh Help me , Help you.
    20 Jul 2003
    Looks awesome...overkill and loss of boot space...but now its all in the leather, it does look very good indeed!
    I wouldn't worry about the staples on the rear, no ones going to see it...except on the door part :)
  6. zanettii
    11 Dec 2008
    Have started on all of them, but i sold my 94" Golf because i got a good offer, and i didnt choose to wreck my other Passat, so i'm trying to get this done as fast as possible. Its a money case in the end, allways is. Had to use over 5000$ to get the new one on the road to, so i'm hanging in there!
    I dont really need space, i just want it to look good! But thanks : )
    I know, but i know myself that it will show, so i need to fix it!
  7. Stickeh
    20 Jul 2003
    zanettii i meant the overkill and loss of boot space as an awesome thing :D
    I'll PM you some pictures of my old install :)
  8. zanettii
    11 Dec 2008
    Hehe, goodgood! :D
    I DO REALLY like it, my girlfriend has a crush on old cars, so she liked it alot to, hehe :thumb:
  9. skreenname
    skreenname SFF Forever
    11 Jun 2009
    The leather looks freaking awesome back there.
    I don't know that I'd do that since I like my trunk, but you did it very well.
  10. zanettii
    11 Dec 2008
    Thanks! I sure do like it myself too:blush:
  11. ToB1
    ToB1 What's a Dremel?
    18 May 2010
    Nice work! :)
  12. zanettii
    11 Dec 2008
    Takker : )
  13. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    I like it!
  14. zanettii
    11 Dec 2008
    But, because of a retarded transport strike we got here in Norway these days, my motherboard will not come for a little time
    I will come with a update with instalation of power supply and such soon!
  15. zanettii
    11 Dec 2008
    UPDATE!
    Now ive mounted the power supply, and sleeved its cables!
    I just have to wait to the strike is over, so my motherboard arrives, then i can do alot more : )
    Pictures of todays work.
    The computer case, ugly outside, because of a bad saw, but this will allso be packed in leather.
    My huge power supply!
    The bolts and screws i'm using
    Hammered in the bottom of the case.
    Power supply mounted
    With all cables mounted. Wait, ugly cables :(
    Power cables sleeved, and hole drilled.
    20pin and power cables sleeved.
    End result!
    What do you think?
    Hold on for a new update soon guys!
  16. Anubus
    Anubus Minimodder
    7 Jul 2008
    Nice psu sleeving:thumb:
    Hope that strike is over soon.
  17. zanettii
    11 Dec 2008
  18. zanettii
    11 Dec 2008
    NOW finally.
    Got my Motherboard and RAM delivered yesterday.
    Now ive just need to get a touchscreen and a SSD, then i'm done!
    Motherboard and RAM in place.
    Will be placed here, behind the panel!
    Switches in place. On/Off Computer, and one i dont have figured to use on yet.
    Cables made.
  19. Anubus
    Anubus Minimodder
    7 Jul 2008
    Nice, glad you finally got what you needed.
  20. zanettii
    11 Dec 2008
    Update?
    Here u go!
    Pictures speaks for it selfes.
    Fan controller and temperature.
    My first idea for frontpanel, but i'm going to use a mesh instead!
    Final resault of todays work, some adjustments are needed!
    More to come soon : )
