Modding ZapWizard- Project: Black Graphic -Nov 24
Discussion in 'Modding' started by ZapWizard, 25 Nov 2003.
  1. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    My Sister, a photographer, and her Husband a computer artist, have been saving up for their first computer.
    (They both have been in college and quite low on cash, I am sure many of you can relate)
    They purchased and shipped all the parts for the PC to me, as they will be in town for Thanksgiving.
    And on with the project log.................
  2. ZapWizard
    19 Sep 2002
    This computer is intended for very heavy graphic design, video and photography use.
    So to start I choose a Athlon 64 3200+ CPU :rock:
    Retail shot of the case, a AMS eMONO
    Features: Cheap (no PSU), Good paint
    Dual USB, Firewire, Mic, Headphone at front of PC.
    I picked out a case that was both cheap, but good looking.
    This case has an automotive like, shiny paint, and a nice plexi front.
    As this is a school PC also, a Zip drive, Floppy, and DVD burner were all included.
    The Floppy and DVD Burner came black in the first place, but the were a very flat black compared to the nice paint on the case.
    So I vinyl dyed them with a shiny black vinyl dye that makes the perfectly match the cases original paint.
    This images shows the reflectivity off the Vinyl Dye on the DVD drive. (And shows of my new MX700)
  3. ZapWizard
    19 Sep 2002
    This case has a green theme, since this PC may be on all the time, super brightness is not needed, rather a subtle effect of lighting.
    I may put a laser etch into the blank area on the front of the case.
    (Above the air holes, and the laser is on it's way soon)
    Two six inch cold cathodes create light out the front and sides of the case.
  4. borumas
    borumas What's a Dremel?
    22 Sep 2003
    Looks nice so far, I would love to have that rig, mmm Athlon 64 goodness. :thumb:
  5. ZapWizard
    19 Sep 2002
    Inside the case is open and clean.
    One CCFL is mounted about 1/4" from the air holes, this lets enough light out without blocking incoming air.
    The other is verticaly mounted as that created the best effect through the side slits of the PC.
    One thing, I wanted to provide, was a way to shut off the Cold Cathodes.
    But I didn't want to cut any holes into this case, as this was a weekend project, and need to be 100% done before thanksgiving.
    So the best solution? Replace the reset switch, with an On/Off switch.
    The Reset switch on a PC is not totaly needed, as you can simply press the power for 4 secs and power back up if needed.
    The reset switch was re-located inside the case (You can see it in the CCFL image above)
    I replaced the switch with an identical push button switch, except that the new switch is Push-On/Push-Off.
    I ripped it off some piece of equipment years ago.
    The new switch was soldered in and works perfectly to control the lights.
    I also replaced the existing Blue Power LED (Which was dim) with a normal green, to keep the theme together.
    The IDE led was not changed, as it is not used with a SATA harddrive.
  6. r3men4nt
    r3men4nt What's a Dremel?
    12 Nov 2003
    mmmm...... athlon 64'nessi want one but im saving up for a [possible mod coming up after christmas!
  7. ZapWizard
    19 Sep 2002
    The system specs are:
    AMD Athlon 64 3200+ :rock:
    Biostar VIA K8T800 K8VHA Pro Motherboard
    ASUS nVidia TI4800 128MB Graphics Card
    1GB of Corsair 400Mhz DDR
    530-watt Dual-Fan PSU
    Western Digital 250GB 7200RPM SATA Harddrive (Rated at 150mb/s)
    56K modem
    The awsome 250GB harddrive.
    Man, does SATA wiring look nice
    The beautiful, and huge TI4800
    This card was choosen as there are specific optimizations for it in the programs that my brother-in-law uses.
  8. ZapWizard
    19 Sep 2002
    More vinyl dye goodness :clap:
    This was a purple Wacom Graphire Tablet.
    I have had it for years, and used it very little.
    I figure a photographer and graphic artist could use it more then me.
    The eye is Mike, from a DVD promo for a Monsters, Inc. DVD
    It is placed under the translucent lift on top of the pad.
    (For putting images to trace)
    Some speakers aquired cheap from a used PC store.
    They were white of course.
    The cases were all vinyl dyed in shiny black
    They are Altec Lansing 33's and have very good bass with a wood subwoofer, not bad at all.
    The mouse used is a Logitech MX300
    It received a small modification: Changing the red LED for a 13,000 MCD Green LED
    The last part of the case, the keyboard.
    Sadly, no modifications needed :waah:, it is black with green leds
    Money shot again, and that is it.
    All put together and lightly modded in just a weekend.
    /Edit: The total cost around $1200
  9. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    looks cool :thumb:
    /me wants
    and happy thanksgiving :)
  10. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    Nice case Zap.
  11. bsodmike
    bsodmike Banned
    11 Oct 2002
    Clean finish ;)
    Does your MX700 give you any charging problems? Mine started to go AWOL after two months of use and right now I'm considering getting a second MX500. The cord is a pain, but much easier than having to recharge the batteries externally and then putting em back in....
  12. complexprocess
    complexprocess What's a Dremel?
    8 Jul 2002
    It must kill you to do such a 'mundane' mod after everything else you've been doing in the last year or so. :) It still has a certain Zapwizard touch to it though, and it's dripping with class. Very nice. :thumb:
  13. tmerelin
    tmerelin What's a Dremel?
    23 Sep 2003
    They are low in cash?
    Athlon64 3200?
    DVD-burner?
    250G HD
    Doesn't sound so....
    I would've opted for something cheaper on these parts and maybe invested in more (and faster memory).
    But anyways, its a pretty cool case with the complete overall unified look! :thumb:
  14. jezmck
    jezmck Minimodder
    25 Sep 2003
    looks very smart - great job. :D
    did you shorten that S-ATA cable? (I've never had the chance to use S-ATA but didn't thnk such short cables would exist...)
  15. HQ08-Modder
    HQ08-Modder What's a Dremel?
    14 Nov 2003
    Pics are buggered.
  16. jezmck
    jezmck Minimodder
    25 Sep 2003
    not from here, try again...
  17. papeniglio
    papeniglio Minimodder
    5 Dec 2002
    It sounds quite strange to see a so low-modded creation from you Zap, anyway it's a great cabinet and I love the black/green theme... Me wants that HD!!!! :brrr:
  18. bradford010
    bradford010 Bradon Frohman
    7 Dec 2001
    Out of interest, what are they?
  19. raxxo
    raxxo What's a Dremel?
    24 Jan 2003
    uh... if you need a POWERFULL computer for grafix and photostuff you save for it...
  20. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    OMG. Love the way this case looks as well as the hardware in it.
