ZapWizard's LAN PC -Custom Ammo PC -Completed Jan 18 '04
Discussion in 'Project Logs' started by ZapWizard, 3 Jul 2003.
  1. Penguin4x4
    Penguin4x4 New Member
    31 Jan 2003
    *looks at clock*
    Quakecon ended about two hours ago....and Dallas is about 2 hours from Austin...so Zap should be home and posting within next hour or two. Can't wait Zap!! :clap: :clap: :rock:
  2. Sid
    Sid Banned
    13 Mar 2002
    You've made a good job of it, certainly. Well done and everything, however, personally I would prefer something light, compact and sexy, especially if it requires to be transported about often eg. lan parties.
  3. Spaced_invader
    Spaced_invader New Member
    25 Sep 2002
    quakecon is just not long enough, the only lan parties i go to are basically hotel conference rooms booked out for the weekend. you can crash at one end of the room and lan in the other end. likw that you actually get to know the people you are playing against.
  4. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
  5. Hiren
    Hiren mind control Moderator
    15 May 2002
    Woa dude you like win every comp you go to. Well done and well deserved! :clap: :dremel:
  6. POET250
    POET250 New Member
    18 Aug 2003
  7. Trekari
    Trekari New Member
    10 Nov 2002
    Is it just me, or does anyone else feel extremely stupid after reading Zap's ideas?
    I'm not creative enough to do cool things like this. I wish that I was. :(
    Maybe I could just outsource my mods to ZapWizard and pay him royalties or something for actually doing them. hehe.
  8. sheardjr
    sheardjr New Member
    7 May 2003
  9. lchyi
    lchyi New Member
    13 Aug 2003
    Hehe Zap, that ammo box is going to bring you a ton of new hardware if you keep lugging it to competitions.
  10. ZapWizard
    19 Sep 2002
  11. Frogbutt
    Frogbutt New Member
    15 Feb 2003
    Any special tech. to cutting the foam for that night visison case? I bought the same case but I want to use it for my paintball gear so im gonna have to do custom foam also.
  12. ZapWizard
    19 Sep 2002
    I have been told a "hot wire" is needed to cut the foam properly.
    I did a totaly hack-job with scissors just to make everything fit.
    I will be buying more foam peices later for a more professional look.
  13. [GiB] Spawny
    [GiB] Spawny Xqpack Lovin
    2 May 2001
    Wouldn't it be nice if you could roll back the lid over the top and not at the side? Kind of looks in the way a bit to me?
    Just a thought :naughty:
  14. xen0morph
    xen0morph Bargain wine connoisseur
    30 Jun 2002
    It's actually very easy to make a hot wire cutter, you need a length of nickel-chromium wire, some way of holding it (a wood bracket with screws works well) and a 12 volt power supply of a respectable amperage (you can use a car battery, but you'd need some form of current limiting.) Most people use several headlights connected in series ;)
  15. ZapWizard
    19 Sep 2002
    I would like if the lid rolled down so that I could use it to stand up the PC like a bench-top insturment.
    I have tried to figure out several other ways of attaching the lid.
    But all of them would require a lot of disctruction of the side hinge, ruining the overall look off the case.
    Instead I am going to make a simple foldable stand I can put under the PC.
  16. Unixmonkey
    Unixmonkey New Member
    17 Aug 2003
    I'm looking at that case right now, and I think you could easily just drill the head off of the long screw, and tap it out. Then replace with another similar gage, but longer, bar with a head to grab on to.
    Then you can drill a tiny hole on the tip end that sticks out, for attaching a small cotter pin. Very military-like.
    That's what I plan on doing.
  17. ZapWizard
    19 Sep 2002
    Hey folks.
    I am NOT done yet!
    I did about 6 more hours of more modding last night.
    And I had a friend with a 6 mega pixel digital camera come over and take some SUPER detailed images.
    So tonight I will have NEW stuff, and 1024x768 images of all kinds of stuff.
    Plus I got a few movies, they may take some time to edit and re-compress though.
    Also my PC was shot on X-Pkay on TechTV, while at QuakeCon 2003 :rock:
  18. Atomic
    Atomic Gerwaff
    6 May 2002
    HAHA! Poor 56k users...
  19. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Zap, I don't know if anyone has posted this yet, but I was just watching X-Play on TechTV and da Lan PC was on. (You must know that they filmed it since it showed a quick thing of the beautiful Morgan Webb asking you about it).
  20. Dragosoft
    Dragosoft New Member
    29 Aug 2003
    oooohhh...
    I Have no word's to say how coll case is that.brrr:
    Keep up the good work:dremel:
    By the way.. where you get that ammunation box?:confused:
