ZapWizard's LAN PC -Custom Ammo PC -Completed Jan 18 '04
Discussion in 'Project Logs' started by ZapWizard, 3 Jul 2003.
  1. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    How can you play with your monitor so far over to the left?
  2. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    A. Its on display so you can see everything.
    B. He can move stuff :D
  3. -Xp-
    -Xp- Minimodder
    23 Jul 2003
    Doesn't the door get in the way of the monitor? Or does it swing back against the side of the case?
  4. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    As TekMonkey said, it was on display for show.
    And yes, the door does get in the way of the monitor.
    If I use the PC at home the monitor sits ontop of the ammo box.
    But, this PC is now basicly a show-piece for events, so I don't use it too much at home.
  5. Cereal
    Cereal What's a Dremel?
    28 Feb 2004
    Now ZAP, i know the 64-51 FX project is supposed to be on "hold" but that pc to the right side of the pic, looks alot like the teasers...is this the big thing, or iam i just imagining things...also RED's pc in the back is a nice touch...
  6. ZapWizard
    19 Sep 2002
    Umm, there is a thread on that PC already in the modding forum.
  7. Noah
    Noah What's a Dremel?
    8 Feb 2004
    Hello Mr. Zap,
    I am amazed at your work. The flow and style in this box, plus the probably hundreds of mods make this the best mod I have ever seen. You have stunned me.
    Question: (it's a dumb but nagging one) Can you close the ammo PC with all the components inside and carry it around in any direction without it falling out? I couldn't tell from your photos/text.
  8. ZapWizard
    19 Sep 2002
    The ammo PC can be turned any direction, and nothing will fall out or get loose.
    Yes, I can close up the entire PC, cables, accessories, tools and all into three parts:
    Ammo PC
    Accessories case and LCD
    Keyboard
    I put the mouse in a container, and LAN party tools in another.
    These two containers fit into the metal case.
    Along with the headphones, cables, CD's, Digital Camera, etc...
    The LCD is in the lid of this case.
    I collapse the custom stand, and put a foam piece over the LCD
    The only things not inside this case is the actual PC and keyboard.
    Here is the PC running veritcaly, which I can't do anymore with the new fan configuration
    The ammo case can then be closed and ready for transport.
    (The external LEDs can be switched over to a battery to keep the effect running)
    The keyboard cable works like a shoulder strap, as it velcro's to the back of the keyboard in a loop.
    And that is it, the entire PC in three easy to move parts.
    Both cases weigh a ton though :duh: (I don't have an exact number)
  9. Atomsk
    Atomsk What's a Dremel?
    13 Mar 2004
    wow. This has to be the most modded pc I have seen yet. Can't wait to see your other work finished.
  10. Atomsk
    13 Mar 2004
    Could you tell me the height of the keyboard? I am thinking about buying one.
  11. ZapWizard
    19 Sep 2002
    Umm, let me see...
    The max height is about 2-1/4" (with feet down)
    But apparently this keyboard is very hard to find (In an english version anyways)
  12. Altron
    Altron Minimodder
    12 Dec 2002
    It looks to me like one of those microsoft "natural" (read: "Crap, I dropped the keyboard on the fllor and it broke, then I glued it back together but the keys didn't line up right so it's lopsided") keyboards.
    What separates it from one of those keyboards?
  13. Vash Theis
    Vash Theis What's a Dremel?
    5 Mar 2004
    ooo
    man...one emotion.... :baby: :jawdrop:
  14. Cheops
    Cheops What's a Dremel?
    13 Mar 2004
    Finally , god forbid me to swear, but finally I complete this log...
    It is just amazing how you use your magic like that, truly truly great craftsmanship. One can only dream of being able to master that kind of skills :sigh:
    I am bout to plunge in the media project so cya in a week or so, i saw it's even longer then this one :eeek:
  15. Noah
    8 Feb 2004
    One more question: Can you remove the components as one large piece if you need to upgrade? If so, how does it lock in when you want to transport it?
  16. ZapWizard
    19 Sep 2002
    To work on the PC, I have to disconnect the faceplate, remove the graphics card, then the rest can pull out the back as one piece.
    It locks with two pins that go in the handles and lock them closed.
    jezmck likes this.
  17. Invisible J
    Invisible J What's a Dremel?
    18 Mar 2004
    Zap, if you ever come through Oklahoma City, and are interested, I can get you parts from military oxygen masks and chemical warfare protection equipment for a very good price (free :thumb: ). For instance, the hose off of an oxygen mask could make a pretty good cable conduit.
  18. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Hey Zap, been meaning to ask you. You like that Laser-Cutter you won?
    Haven't seen ya mention it...was just curious. :D
  19. Cereal
    28 Feb 2004
    for everyone that is interested in a keyboard that is like the one ZAP used in this project, i found this one when doing a search for usb keyboard on google....it is called the Macally ikey...do a google image search you can see it...umm, it comes in the "color" ice which is basically a semi-distorted clear base and the keys can be black or white...so, if you put some cold cathodes on the bottom, you will have an authentic ZAPWIZARD looking keyboard!!! I am unsure how to put up a picture, but i will put a link to one in this post....
    image gone...
    and...
    image gone....
    ok,there they are...
    [EDIT] I figured out how to put up pics :) also, the keyboard has a 2port usb hub on the side of it...an added bonus incase you dont have any usb port on the front of your case or if you want usb ports like on a laptop...for a little keyboard light or something...!!![/EDIT]
  20. Cereal
    28 Feb 2004
    you like? zap, are these like what you used?
    [EDIT] well, i just looked back at the pics of you system zap, and the keyboard is all black, but wont this keyboard do semi-good for the cold cathod's underneth? ok, thats al i have to say about it! :)[/EDIT]
