ZapWizard's LAN PC -Custom Ammo PC -Completed Jan 18 '04
Discussion in 'Project Logs' started by ZapWizard, 3 Jul 2003.
  1. JavaDog
    JavaDog New Member
    13 Mar 2004
    Not sure which of Zap's KB's you meant.
    But Kensington :www.Kensington.com : has a similar one to the ones you posted.
    http://www.kensington.com/images/64350M.jpg
    None of those look like any of Zap's KB's I ve seen though...
  2. Go4t
    Go4t i
    13 Dec 2003
    i think that Macally ikey is meant for a mac there is one being used in the mac lab at my school it has video editing stuff on it tho
    i think zap has an ergonomic kb for the lighted one
  3. mclean007
    mclean007 Officious Bystander
    22 May 2003
    No offence, but that is really nothing like Zap's Keyboard. His is an Ortek EKB-880 (http://forums.bit-tech.net/showpost.php?p=358193&postcount=6). The most similar thing I can think of is Microsoft's ergonomic keyboards.
    Oh, and www.microdocusa.com and www.drbott.de might have something to say about you leeching bandwidth from them :nono: - the rules on this forum are you must host your own images. Try a free image host like www.uploadit.org
  4. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    I have seen those keyboards at CompUSA, and some of them are even made by Ortek.
    But they will not fit two 12" cold cathodes inside, so you would have to use EL Wire, which is not as bright.
    I want to build other keyboards like the ammo PC has, but the keyboard is no longer made.
    Of course there are the pre-lit keyboards out there, but most are tiny.
    But I just reviewed a model from Zippy.com that I like, it is near full size, and good for gaming.
    http://www.zapwizard.com/reviews/zippy
  5. n0ll4k
    n0ll4k New Member
    1 Jun 2003
    the ortek keyboard just rules i have one at my main rig und searching ebay for another one for my server.
    but i think i have to backlight one with ccs :D
  6. Cereal
    Cereal New Member
    28 Feb 2004
    ok, ok, it's nothing like zaps but i thought it would be pretty cool to show, and yes, i agree, i think it is for the mac.....so you can stop elling me that it isnt like zap's at all...and as for the forum rules, i will remove the links immedietly....
  7. Kosmo2
    Kosmo2 New Member
    20 Jul 2002
    Backlit Keyboard
    Hi Zap , Do you think its possible to mod the backlighting and LEDs on the zippy keyboard to green instead of blue ??
  8. Noah
    Noah New Member
    8 Feb 2004
  9. Altron
    Altron Well-Known Member
    12 Dec 2002
    You'd need to rip it apart and replace the blue el with green el.
  10. Kosmo2
    Kosmo2 New Member
    20 Jul 2002
    Ya I figured that , My question really is can you obtain a Green EL and replace the blue ??? and if so where would you buy a green EL from ?? I kind of assumed it was a custon EL panel specifically made for this keyboard and not possible to replace . .
  11. Altron
    12 Dec 2002
    I don't know what it uses, you'd need to find someone who has it to take a peek under the keys.
    EL wire is pretty easy to get, EL sheet is more difficult but still possible.
  12. Kosmo2
    Kosmo2 New Member
    20 Jul 2002
    Ya thats what I figured , but I assume that the EL is a Sheet made specifically to go around the keyboard switches . . . . Probably no green available but maybe the sheet can be replaced by the EL wire and get the same or similar affect . . . . . .
    Thanks for the reply
    Mick
  13. Altron
    12 Dec 2002
    Yeah, I would start at one end of the keyboard, run EL all the way across, then move it down an inch and go back across, like so:
    Code:
           letters              |
  14. Kosmo2
    Kosmo2 New Member
    20 Jul 2002
    Do you think the light spread from EL cable would be adequate ?? I havent actually seen this stuff in real life only on the internet . .
  15. Altron
    12 Dec 2002
    Well, the keys are translucent, i think it would diffuse the light rather nicely. Similar to the effect you get when putting a LED behind a frosted piece of plexi.
  16. Kosmo2
    Kosmo2 New Member
    20 Jul 2002
    Sounds cool . . . Maybe I will invest in one and some cable and have a play with it . .
    Thanks for the input
    Mick
  17. Muke195
    Muke195 New Member
    9 Mar 2004
    You've talked alot about the VGA to BNC cable you modded with the custom jack but don't most monitors now a days are svga and require extra wires for the monitor id features how did you get it down to ten wires and did you lose any features with the monitor or video card?
  18. ZapWizard
    19 Sep 2002
    They have them, but do not require them.
    I just used the pure analog RGB and VSync and HSync signals.
    (And each has a ground)
  19. Noah
    Noah New Member
    8 Feb 2004
    Hey, what type of motherboard/power supply fits into that case? Seems a little small.
  20. ZapWizard
    19 Sep 2002
    A normal MicroATX motherboard. (1 AGP and 3 PCI slots)
    The powersupply is also a MicroATX standard supply, but compacted slightly by using multiple smaller fans.
