ZapWizard's Media PC -Project on hold
Discussion in 'Project Logs' started by ZapWizard, 4 Jan 2003.
Thread Status:
Not open for further replies.
  1. Frogbutt
    Frogbutt What's a Dremel?
    15 Feb 2003
    This site has "Blood red" color el sheet but its DAMN expensive
    link <-- click 94 Customizable EL Sheets and Kits if link doesnt wrok correctly
  2. Yo-DUH_87
    Yo-DUH_87 Who you calling tiny?
    6 Mar 2002
  3. Altron
    Altron Minimodder
    12 Dec 2002
    A mere $108.
    Although consider you got the remote for $30 and it originally costs $100 It only cost a total of $138 to mod it so the EL sheet was only $38... :lol:
  4. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    Hmm, the LED's are looking better all the time....
    I saw that website, that is why I said:
  5. NiHiLiST
    NiHiLiST New-born car whore
    18 Aug 2001
    LEDs should be okay surely? They might use more power but it's not like they'll be on all the time.
  6. ZapWizard
    19 Sep 2002
    If I used three super bright LED's along each side, that would consume 40mA (Two sets of three in series at 20mA)
    My biggest problem is making the light look even across the display. (Even defusers won't help with that)
    I will just have to experiment I guess...
  7. complexprocess
    complexprocess What's a Dremel?
    8 Jul 2002
    Awesome find Zap. I'm sure everyone will keep an eye out for the sheet for you. (half of the people on the internet are watching this thead, no doubt; it's just that cool)
    OFF TOPIC
    Why not try your hand at designing guitar electronics, effects, or amps?
  8. ZapWizard
    19 Sep 2002
    I do like analog, but the math to properly make effect, and music sound good (Curves and such; Is just beyond my skill.
    In fact I build an analong 5.1 to 4 speaker mixer for my, Surround Sound headphones (on my site)
    But that project is on the backburner until I convert it to all digital.
    As far as the Media PC's current status:
    I still have to get two thermistors for reading the CPU's heatsink Temp, and Air intake tempatures.
    The remote needs new backlighting.
    The last of the testing on the Microcontroller board is nearly done.
    I will make a PCB for that.
    That will be the last of the electronics.
    After that I will worry about software and programming the microcontroller.
    So far the only programming I have done is in short blocks.
    I need to put it all together and make it automatic.
    Once that is done I can start on the plexi....:clap:
  9. v3rt
    v3rt What's a Dremel?
    20 Apr 2003
    Mindboggling :)
    Good luck, this r0x!
    [Thx // Dan]
  10. Confusitron
    Confusitron What's a Dremel?
    22 Dec 2002
    But still, the fact that I play music may take time away, although I really don't play at all right now because I'm thirteen and I don't have a band. I guess studio stuff would work. WAIT! I AM ON AN AUDIO FORUM! THAT IS WHERE I MAY GET SOME MORE POWER IN BOTH MUSIC AND ELECTRONICS!
  11. BasicBubbleHJK
    BasicBubbleHJK What's a Dremel?
    4 Feb 2003
    aren't all EL products turquiose to start with, but have quite a wide spectrum. If you buy red EL wire isn't just turquiose with a red filter?
  12. [twig]clown
    [twig]clown What's a Dremel?
    1 Jan 2003
    Two things i can say:
    1) WOW! (and say it lots)
    2) Bring on the plexi !! :clap: :clap: :D :D
    -cLoWn :hip:
  13. Green Soda
    Green Soda What's a Dremel?
    26 Dec 2002
    Take a sheet of plexi, and sand the hell out of both sides!! Put the leds on the sides, and it lights up rather evenly! Im doing this in my calc mod, and it looks good. once i get off my lazy ass and buy the stupid surface mount leds, i'll post some pics....sometimes putting a sheet of paper on the back helps also...
  14. leber
    leber What's a Dremel?
    7 Dec 2002
    hey zap, first off great work, as for lighting up the remote will these maybe help
    edgelights
    they are edge lights like those used in cellphones, and the digidoc 5. They might be able to spread the light out like your lookin for
  15. ZapWizard
    19 Sep 2002
    Ah, those are nice.
    But I am on a budget now, so
    I tried the sanded plastic, but that does not do much, as I have to use pretty thin stuff to get it under the LCD.
    I tried wiring 6 LED's but they just pass the light straight through the glass.
    I tried using the small cold cathode out of a Compaq IPAQ.
    But it's not enough voltage to get it to trigger. (The Remotes inverter puts out ~60-100volts)
    I tried even running 6 LED's in series with a 2k resistor, off the inverter!. (To save battery power)
    But since the inverter can't put out much current they did not reach 100% brightness.
    What does work?
    I put a layer of electrical tape along with a layer of Aluminum tape on top.
    This will act as a reflector for an LED.
    The only thing is I need about 1mm of extra space to get the LED to properly light the screen.
    (One 6000MCD LED can light half the screen brightly)
    I have the 1mm of working space between the LCD and the face plate, but the LCD's sponge connector, doesn't reach this far.
    (You have seen them if you ever took apart a LCD product that wasn't hardwired)
    I hope to get a 1/8" piece of plexi under the LCD.
    My options are to try to swell up the connector pads with solder, and hope the LCD make connection.
    Or cut up a 1/8" plate of copper and solder those onto the LCD's connector pads.
    (This soulds like a better option.
  16. [twig]clown
    1 Jan 2003
    All sounds a tad complicated and accurate for my soldering skills, good luck!
    -cLoWn :hip:
  17. Darkness
    Darkness What's a Dremel?
    8 Dec 2002
    paint one side white and polish the sides to allow more light in.
    Thats how i changed my green array backlight lcd to blue.
    pics -> http://members.iinet.net.au/~fletch4/
  18. ZapWizard
    19 Sep 2002
    That is the plan, but I need to get a 1/8" peice of plexi under the screen first, hence I need to raise the LCD an 1/8 of an inch
  19. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    How much as postage and packing for your BasicAtom PRO? They don't seem to have any details on the website about postage costs or details about shipping to the UK (or any other country).
  20. ZapWizard
    19 Sep 2002
    I think it was just like $6, well worth it considering the alternative is $50.
Thread Status:
