ZapWizard's Media PC -Project on hold
Discussion in 'Project Logs' started by ZapWizard, 4 Jan 2003.
Thread Status:
Not open for further replies.
  1. Malvolio
    Malvolio .
    14 Dec 2003
    Zap, you are a god. I've been going through your site and all of your posts here on bit-tech, and all's I can say is, you are a god. You've given me so much inspiration and so much technical insight that I never even would of imagined. Right now I'm totaly reworking my main computer, rewiring just about everything and doing amazing things with plexi glass.
  2. Evilnads
    Evilnads What's a Dremel?
    1 Jan 2004
    I know that you want to access some functions of the lcd outside windows, but most if not all functions won`t work (tv tuner etc), so why don`t you use a full colour lcd designed, say for a gamecube (5" diagonal) and use the second output of the video card for display. a usb joypad could bed cannabilised for input, or for the ultimate mod, a small touch panel from http://www.magictouch.com/builtin_lcd.html . bought one for a 15" Samsung TFT and have not looked back. Not only that, but it would also display Video, fullscreen and full motion, plus no need for any buttons. I have read most of the thread, but not all so please forgive if someone has posted suggesting this already.
  3. dudeyourmomiscute!
    dudeyourmomiscute! What's a Dremel?
    14 Dec 2003
    gj Zap i really like the media pc! i know your working on a fully functional remote for your project, are you planning for a wireless keyboard and mouse build into a livingroom foot cussion? Would be a cool idea to just lift it up and do whatever then put it back down.
    maybe even have a powercell put into the stool to power them so you don't have to waste batteries..
    anyways just my ideas, keep up the work!
    Tim
  4. Pistol
    Pistol Guest
    Zap...what about glowing feet, have you thought about that? a soft low voltage LED perhaps?
  5. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    God, it took so long reading through the "omg this is gonna rawk" posts to actually find anything
    I hope it can live up to the hype you've injected into it. Been a long time since anything's happened tho. In fact it's been so long, the thread should be moved out of project logs if following the rules ;) ;) :lol: :lol:
    sounded a bit more negative than i intended. best of luck with the project, sack off all that unimportant life/work and get going tbh!
  6. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    dudeyourmomiscute: Yes I am using a wireless keyboard and mouse. The receiver is even hacked for longer range.
    Pistol: I thought about that at first, but decided on effect lighting around the edges for a UFO glow look under the whole PC.
    mrplow: I know, I know.
    My current project (No log yet) will help me learn more about making the case properly.
    After that all I need is programming.
  7. dudeyourmomiscute!
    14 Dec 2003
    Zap, how is the case going to open? are you conna have a spring loaded or motorized opening rail so when you push a button it slowly, smoothly opens?
    just a thought, keep up the good work!
    Tim
  8. ZapWizard
    19 Sep 2002
    I plan on a sliding motherboard tray out the back.
  9. Malvolio
    Malvolio .
    14 Dec 2003
    Hey Zap, don't know if you covered this or not (tried searching for it, no luck), how did you extend the range on your wireless keyboard and mouse? Wouldn't mind doing that for my Retro Media Center rig (on/off switch can be used from like 30 feet away, so why not the keyboard/mouse?).
  10. dudeyourmomiscute!
    14 Dec 2003
    Zap, are you gonna use a light theme? Also what material are you going to use for the case? aluminum?
  11. mrplow
    5 Sep 2001
    Good good :)
    I'm also interested in the expansion of the wireless peripherals' range... how did you do that?
  12. ZapWizard
    19 Sep 2002
    Took forever to find, but here:
    http://forums.bit-tech.net/showthread.php?postid=301678#post301678
    All Red, and nothing but LEDs for as pure red as possible.
    I hope to have the case 100% acrylic
  13. dudeyourmomiscute!
    14 Dec 2003
    Hey Zap what tube are you going, planning to hook this monster up to?
    one more thing are you going to use red acrylic?
    keep up the nice work!
    Tim
  14. ZapWizard
    19 Sep 2002
    I plan on using a 17" CRT monitor with 1600x1200 resolution at first. Later this will be the host for a DVI connected projector to use as a TV.
    I plan on all clear acrylic, with tinting and paint like MacroBlack.
    My next project will actualy have many of the case features that the media PC will have. (But simpler)
    So it will be my experimenting ground for the MediaPC.
    (yep, another huge project log on the way)
  15. xcosta54
    xcosta54 What's a Dremel?
    5 Jan 2004
    Zap you are the man!! :thumb:
  16. jay
    jay What's a Dremel?
    25 Nov 2003
    on the front panel would it be possible to use automamed motor driven IR key ring something like the sys power up switch by 3N1GM4`s blooooooo mod ?
    if this as been mentioned before i`m sorry but i`ve only just found this project log and it`s looking daaaaaaaaaam good :eeek: and if it`s finished by mid feb you could giv it me as a birthday prezy :D
  17. planki
    planki ...
    20 Dec 2003
    zapwizard i know that you are going to use your ipaq to try and control your htpc i found this link on the web and didnt know whether you would be able to use this software or the basic principal of this to aid you.
    Netremote
  18. ZapWizard
    19 Sep 2002
    Thanks for the link, that looks like it will be good to run on other PC's when I get this done.
  19. cavitycr33p
    cavitycr33p What's a Dremel?
    11 Jan 2004
    Any updats on this zap, sorry if I missed something, this project is most def godly
    "Bows"
  20. ZapWizard
    19 Sep 2002
    Late update was way back in July of '03
    The project is not dead, but on hold.
    I am currently building a new Athlon 64 FX watercooled system.
Thread Status:
