Case Mod - In Progress ZdMods | Project 180 | Final Pics 20/12/13
Discussion in 'Project Logs' started by Meelobee, 27 Dec 2012.
  1. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    brilliant idea, loving it so far,
    keep it up
  2. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Well this is looking rather special. I live the pillar front. And with the IO shield facing downwards.
    Yup, looking great! Can't wait for more.
  3. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Thanks guys :)
    During the week I received a package from Coolermaster, they decided to sponsor my project and send me a very nice Silent pro M2 1000w psu and 7 Excalibur 120mm fans.
    Big thanks to Marco from Coolermaster Benelux for making this happen :thumb:
    And I also have a small update:
    Did a bit more work on the top of the case. I've put plexi and aluminum corners onto the bars that hold the sidepanels.
    This way each side of the top looks like it's made out of two bars with plexi in between. And I still have room to put a 360 radiator right under the top of the case :hip:
    And I've used a small piece of alu tube to make the backside of the top
    [​IMG] [​IMG]
    Sponsored by
    siliconfanatic likes this.
  4. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    0_0 have some rep! :thumb:
  5. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Subscribed, liking where this is going!
  6. Meelobee
    5 Nov 2003
    Thanks! :thumb:
    During the last weeks I've collected some some hardware for this build:
    CPU Block (I won this with Inverted in the CooledPC compo from EKWB.)
    OZC Vertex 4 128Gb ssd
    Alphacool Nexxos ST30 240 & 360
    360 with Coolermaster Excalibur fans
    The 360 radiator is bolted to another angled piece of aluminum. This piece is attached to the existing bolts that hold together the tubes, plexi and the corner. Because of this there are no visible screws, and I could clamp the hex mesh between the 2 corners.
    Top of the case (Upside down on this pic)
    [​IMG] [​IMG]
    Sponsored by
  7. elAwesome
    elAwesome What's a Dremel?
    1 Nov 2012
    Awesome!!
    I really like the design so far!
  8. Meelobee
    5 Nov 2003
    Thanks elAwesome :)
    The top is almost done, just need to make a small alu piece to fill the hole on the front of the top. And ofcourse it needs a nice finish (brushed) and the mesh might be spraypainted.
    I've installed both rads., ufortunately I've made a small mistake while making measurements. As a result of the mistake the front rad was too high in the front and the fittings didn't err... fit.. So I had to turn the rad upside down, with the fittings on the bottom. A bit harder to fill the loop now, but no biggie :)
    Because of the orientation of the front rad the copper between the fins is clearly visible. (with the rad's fittings on top this was less visible.) Can I just paint the fins?
    [​IMG] [​IMG]
    Sponsored by
  9. fr0Zen
    fr0Zen back i guess
    25 Oct 2011
    yes you can just paint them but it will give worse thermal preformance
  10. Meelobee
    5 Nov 2003
    Been a while since the last update, modding is going slow lately, too much stuff to do and too little time...anyway I did find some time to do some small things;
    First I tackled the issue with the visible copper on the 240 rad. Instead of painting the fins I decided to hide the whole rad behind a cover. So I cut some profiles
    Cut a piece of aluminum and attached the mesh with metal putty
    both attached to the rad
    The 360 rad in the top is hidden with 2 aluminum pieces too
    From the side you can't see the rads anymore
    To get a bit more fresh air into the case I've added two holes in the backpanel, these will be finished with mesh
    Installed 3mm white leds in the front, the plexi needs more sanding so the lightning isn't equal yet
    [​IMG] [​IMG]
    Sponsored by
  11. Pranja
    Pranja Blackwolf
    18 Dec 2011
    That rad grill looks sexy. :rock:
  12. elAwesome
    1 Nov 2012
    Oooh damn, that's some nice metal work!
  13. whyte
    whyte What's a Dremel?
    27 Mar 2012
    Not sure if this has been answered already, but are you going to put the psu in the front of the bottom chamber?
  14. Waynio
    Waynio Relaxing
    20 Aug 2009
    This is going to be an excellent before & after comparison. :D
    Looking good. :)
  15. Meelobee
    5 Nov 2003
    Thanks guys :)
    Actually I'm not 100% sure yet. Most likely it will be installed in the back. It would be the easiest place to install it and get the exhaust on the back of the case too. But installing it there would interfere with the i/o ports, which face downwards. I still have to think of a nifty way to solve this, so far I've came up with 2 options, either a hinge or some sort of panel I can slide in and out from the side.
  16. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    I seriously love that front man!
  17. siliconfanatic
    10 Sep 2012
    Sometimes I wish I could think of non-overkill ideas. The design of this is just plain brilliant :thumb:
  18. WaRn00b™
    WaRn00b™ bit-tech addict
    14 Jan 2013
    Very interesting indeed. Subbed! :D
  19. White-Fox
    White-Fox What's a Dremel?
    11 Feb 2013
    it looks.... AWESOME!! keep up the good job!
  20. ry@n
    ry@n Minimodder
    31 Aug 2005
    I really like this, it almost looks factory made. The front panel and mid section are really well thought out and executed. Nice to see something different.
