Case Mod - In Progress ZdMods | Project 720 | Started on the top - Oct 17
Discussion in 'Project Logs' started by Meelobee, 12 Dec 2013.
  1. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Looks great dude. Nice to see some one with more money than me modding a Dell :D
  2. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Thanks Andy :) Love the paint on your TVR Dell. Not sure on the more money part, lack of funds is one of the reasons for the slow progress..
  3. OrangeClockwerk
    OrangeClockwerk Clockwerk Industries
    28 Jul 2013
    You got my vote for MOTM bud! Keep up the awesome work!
  4. Meelobee
    5 Nov 2003
    Thanks Jim :)
  5. Hukkel
    Hukkel James' minion
    20 Dec 2012
    Realy coming along!
    Don't use the standard waterblock of the mobo though. I believe it is aluminium.
  6. Meelobee
    5 Nov 2003
    I won't, there is a kit from EK that I want to replace the standard block, it also replaces the heatsink on the southbridge:
    http://rog.asus.com/285582013/news/ek-water-blocks-releases-new-maximus-vi-formula-water-block-kit/
    Small update:
    Worked on the midplates today, now all 6 of them fit in the case with the mobo installed. I need to wait untill I have the RAM and mobo waterblock mentioned above to completely finish the panels. I need those parts to measure their size for the cutouts. But for now..all the panels are in, together with the mobo! :clap:
  7. Asouter
    Asouter --------
    18 Jan 2012
    Catching up with my fave' builds ... Looking good man ... I have been having a drool on fb with your updates there :)
  8. Meelobee
    5 Nov 2003
    * Small update!
    The cpu block for this build is an EK Supremacy CSQ, I don't really like the frosted look. So I decided to polish the block using sandpaper and some silverpolish :)
    Looks much better if you ask me :)
    For those intrested, here's a small tutorial video by l3p on how to polish your CSQ blocks:
    Oh and this build is nominated for MOTM, please vote if you haven't already! :)
    http://www.bit-tech.net/modding/mod-of-the-month/2014/03/31/mod-of-the-month-march-2014/7
  9. Shurika
    Shurika Minimodder
    9 Mar 2012
    Meelobee, please, put the EK logo back on the block. Great polishing, but without the logo it looked incomplete
  10. hero1
    hero1 Minimodder
    18 Oct 2013
    Good job with polishing the cpu block.
  11. TheMadDutchDude
    23 Aug 2013
    That block looks sweeeet!
  12. Falqoon
    Falqoon Minimodder
    13 May 2013
    Awesome!!!
  13. Zsolt Guriga
    Zsolt Guriga What's a Dremel?
    20 May 2012
    Awesome work,and very clear,also the polished water block is my favorite:thumb:
    Btw I agree with Shurika,without the EK logo is little bit crude,but I am sure that you have maybe other plans with it.
  14. Meelobee
    5 Nov 2003
    The logo was damaged, there's a big scratch on top of it, so I'll replace it with something custom :)
    Thanks guys :)
    Thanks Zsolt :) I agree too, it's missing something without the logo. I'm actually doubting if I should use this block for this build at all, as it doesn't match that much with the rest. Maybe it's better to get a full metal block instead.
  15. Shurika
    Shurika Minimodder
    9 Mar 2012
    sorry to hear that, but I think you can imagine something certainly:rock:
  16. douglas alves
    douglas alves Minimodder
    3 Mar 2014
    Muito bom seu projeto ...gostei muito
  17. Meelobee
    5 Nov 2003
    A while ago I came into contact with Asus Benelux. When they saw this build and heard about the plans for the rest of the build they decided to step up and sponsor the project with not just one, but two of their Radeon R9 280x cards! A pair of very awesome cards, that will take this build to a new level hardware wise! Thanks alot Asus! :)
    Ofcourse both cards go in the build, so I had to make the holes for them:
    Both cards just in
    The left sides of the cards hang a bit because of the weight of the heatsink, the waterblocks weigh less, so it should be ok then.
    Made a simple lock for the videocards
    Took the midplate assembly apart and drilled a 10mm hole (biggest drill I have) through all the plates (18mm thick in total) and filed the hole to 25mm
    Made a ring from 3mm alu sheet, inner diameter is the same as the inner diameter of the tube
    Ring is epoxied to the bottom of the lowest midplate, preventing the tube to fall all the way through.
    The tube will be used for the 24Pin wiring, it should be just big enough to hold 24 sleeved cables, but it's going to be a tight squeeze :)
  18. -MisterX-
    -MisterX- Minimodder
    22 Apr 2014
    Stunning work! Congrats on the sponsorship=)
  19. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    Man, this is great. You modded that case so heavily you could almost call it a scratch build. Probably the best 720 mod I can think of.
    Also congrats on getting sponsored.
  20. Hukkel
    20 Dec 2012
    Congratulations on your sponsorship.
