Scratch Build – In Progress ZdMods - Project pǝʇɹǝʌuı - Final Pics! (post #273)
Discussion in 'Project Logs' started by Meelobee, 8 Mar 2012.
  1. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    A couple of days ago I received the 2nd pass-through panel and with it I've finished the wiring for the videocard. The wires have been cut to length and have been sleeved with Paracord. The 13th (still empty) hole is for the wire of the powerbutton.
    And I've almost finished the mounting bracket for the videocard:
  2. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Video card mount looks great. as does the the gpu cable pass through:thumb:
  3. Lehani
    Lehani What's a Dremel?
    27 Jun 2012
    Hey Meelobee, you still those messurements on the GFX?
  4. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    GPU cable passthrough is pure win, win, WIN!
  5. alain-s
    alain-s Minimodder
    12 Jan 2011
    The GPU mount is looking great. But the stickers of the Corsair ram don't really fit the colour theme. :p
  6. Meelobee
    5 Nov 2003
    Thanks guys :)
    Lehani: Nope, not needed anymore, I used my current card to do the measurements, the backplates are universal so I should be ok.
    Alain: It's on the todo list, Either the same stickers in blue, or custom ones with my own text.
  7. SilveR_172
    SilveR_172 Minimodder
    24 Nov 2011
    Like the PCI protectors your using mate looks nice !
  8. Meelobee
    5 Nov 2003
    The PCI protectors come with the motherboard :)
    Took a while, but finally I got all the parts painted. Last 2 I needed to do where the left sidepanel and the GPU bracket. After painting I installed both. The black dots are the heads of the bolts that hold the parts on the inside, they won't be visible when the mobo is installed. :)
    The inside, it's gonna be a hell of a job to make everything fit and close the case. Sata, 24pins ATX (incl plugs) & EATX wiring all have to fit in there somehow..
  9. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Oh my, that does look rather good.
  10. Lehani
    27 Jun 2012
    #Meelobee that just looks fantastic :D :D really goood job :)
    still i want to see if you doing any painting or modding to the hardware's shield :)?
  11. Phyonics
    Phyonics What's a Dremel?
    4 Oct 2011
    It's gonna be a tight fit, but it looks fantastic mate :thumb:
  12. Meelobee
    5 Nov 2003
    Thanks again guys :)
    Lehani: Not the whole shield, but I've got some ideas for some highlights :)
  13. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    Very well done. Nuff said.
  14. Meelobee
    5 Nov 2003
    Thanks maestro :thumb:
    Haven't done much last 2 weeks, because I've been on holiday and spend some time with family, But I do have a small update on what I did after my holiday.
    (phonepic)
    Hopefully I have a bigger update somewhere this week :)
  15. MeddlE
    23 May 2011
    We haven't forgotten you, looking forward to further updates.
  16. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    I wish you're using blue coolant... :)
  17. Meelobee
    5 Nov 2003
    Your wish is granted jay2:
  18. jay2
    3 Oct 2012
    :clap: you :rock:
  19. Phame
    Phame COOOOFFFFEEEEE
    17 Sep 2012
    I hope my mod turns out this clean, shame its still in design mode.
    Amazing work MeeloBee.
    Keep it up!
  20. Lehani
    27 Jun 2012
    it looks so awesome...
    But:) why havent you watercooled the GFX?
