Scratch Build – In Progress ZdMods - Project pǝʇɹǝʌuı - Final Pics! (post #273)
Discussion in 'Project Logs' started by Meelobee, 8 Mar 2012.
  1. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    ... and now you've incorporated one of my favourite mods. This just gets better.
    HOW did you get the GPU power line to bend to perfectly...?
    I love this build more and more each time I see it.
  2. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    What GPU?
  3. Tattysnuc
    19 Jul 2009
    Apologies. It was the GPU on Chillers mod. On yours you are using it to power the EATX port...
  4. haggisathome
    haggisathome What's a Dremel?
    1 Oct 2003
    :thumb:fantastic workmanship:thumb:
    your project is cleaner than clean dude
  5. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    Thanks and sorry to disappoint, pictureless update today :(
    Nope it's been done before (Chiller has solid bars on his vidcards) Main reason I used these is that I had em laying around. And ofcourse the bars will be isolated, as I said between the pics :)
    Sir Yes Sir! :D (Looks like text between 2 pictures isn't read.)
    Thought about that option too, but chose to keep the top clean :)
    Thanks Tattysnuc, the bending was easy, the bars are only 2mm so I just used pliers.
    and yeah what GPU?! :D
    Thanks haggis! :)
    I think I'm going to redo the bars, but this time I'll make them out of 3mm copper, which should be alot better in regards to handling the currents. The problem is 3mm copper bars are hard to get here...
  6. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Those atx power rods look awesome I cant to see their finished look. Maybe you could chrome plate them then insulate with some sort of thick clear layer.
  7. Meelobee
    5 Nov 2003
    hmm chrome could be cool.. but no, the rods will be matt black, so they'll blend in with the mobo (on the pic below I've covered them with black heatshrink)
    I like to use alot of cleartube for the looks, but I'm not sure if this will hold, what do guys think, will this corner hold like this:
  8. Waynio
    Waynio Relaxing
    20 Aug 2009
    I don't do water cooling, nearly everyone else does though, :D should still be good & solid I'd expect with it all being quality parts.
    Sure someone who knows for sure will soon say but my guess is it will be fine. :)
  9. Squigly
    Squigly MODfiend.. ~twitch~
    20 May 2012
    Those look like rotary fittings, I find with mine after I have run the loop for a bit the rubber washers seem to seat themselves rather well and almost stick in place. I would assume its the heat and the pressure in the system. Also there wont be to much water on that corner so im pretty sure the corner will hold up well.
  10. Meelobee
    5 Nov 2003
    Allright I'll keep the corner like that :)
    Update!
    So yeah the brass rods.. They looked cool, but material wise they were crap. So I redid them, this time in 3mm solid copper :D
    The connectors on the rods are isolated 2 layers Plastidip (rubberpaint) and the rods are isolated with heatshrink:
    Bonuspic:
    Squigly likes this.
  11. Foregasm
    Foregasm What's a Dremel?
    3 Apr 2012
    that last pic...is amazing...so awesome...can't think of worthy praise...
  12. The boy 4rm oz
    10 Apr 2008
    Fantastic idea for the mobo 8 pin, looks really slick!
  13. Furball Zen
    25 Jan 2012
    Yea it looks good, but just doesnt fit with the theme.
    Maybe you should do another piece like the 24 pin and have them come out here and arc over
  14. Meelobee
    5 Nov 2003
    Thanks Foregasm, I quite like the look of it myself. Final leds will be RGB strips :)
    Thank you The boy 4rm oz :)
    It doesn't fit yet, hopefully it will blend in more after I've done the GPU connector in the same style. However I thought about the option you drew but that would mess up the lightning in the top of the case. And I'm not sure if a bundle of cables on the top of the case would look nice. It will probably break the clean look it has now.
  15. Meelobee
    5 Nov 2003
    No update yet (sorry!) but something else:
    As many of you probably have seen I've 'won' Mod of the Month may 2012 right here at Bit-Tech . (w00h00!)
    A big thank you to everyone that voted for me, you guys :rock:
    I hope you enjoy the rest of the build as much as I do ;) Till next update!
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Think I will :D congrats mate. :clap:
  17. abbas-it
    abbas-it We came, we saw, we mod, you awe!
    1 Jun 2011
    hey melobee, congratulations buddy, great work and well deserved mod of the month.
    will be keeping an eye on your progress, keep it coming. :)
  18. Meelobee
    5 Nov 2003
    Thanks Waynio :thumb:
    Thanks abbas-it :) Following your build with pleasure too!
    Small update
    Yesterday I've spend some time on sanding (up to P600) a couple of small parts. This morning I sprayed them with primer. After a couple of hours drying I've sanded them again and applied a 2nd layer of primer:
    Naked shot:
    After priming:
    I like how the edges of the meshed parts seem to be made out of 1 piece :eek:
    Till next time :hip:
  19. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Oh my, does this mean the whole thing is getting painted?
  20. Furball Zen
    25 Jan 2012
    If white is the color and youre not using auto paint, i suggest epoxy paint, like is used on refrigerators. That would be SWEET.
