Scratch Build – In Progress ZdMods - Project pǝʇɹǝʌuı - Final Pics! (post #273)
Discussion in 'Project Logs' started by Meelobee, 8 Mar 2012.
  1. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
  2. MeddlE
    MeddlE Norwegian Blue
    23 May 2011
    Looking very nice, good paint finish too.
  3. Meelobee
    5 Nov 2003
    Thanks Meddle :)
    Question time, I'm about to apply a coat of clear paint on the parts that are already painted. But I'm not sure if I should sand the last layer of colour before I apply the clear coat, or just appy the clear coat over the last layer of colour without sanding. Is there anyone here that knows what gives the best result?
  4. Squigly
    Squigly MODfiend.. ~twitch~
    20 May 2012
    SAND IT!!!! specially if your looking for a nice clear mirror finish, Use minimum 600 grit but preferably 1200 grit water paper, wont take to much sanding, when you first start sanding with the water you will find the paper "grips" a bit more, once it goes nice and smooth and the paper slides easily.. move along..
    But trust me on this.. sand it!! the finish is FAR better
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    ^Sounds a good tip. :)
    The look at the moment looks excellent but I guess it can be even better so why not. :D:dremel::rock:
  6. Meelobee
    5 Nov 2003
    Small update!
    Sanding and painting is a time consuming business, so I'm a bit slow with updates recently. Good news is that I have completely taken the case apart and sanded most of the parts in preparation for painting. I've also finished painting a couple of parts:
    The PSU housing:
  7. MeddlE
    23 May 2011
    Wow, excellent finish on the paint, this is going to look superb. Heck, it already does.
  8. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Awesome paint work if only I could paint like that. :thumb:
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    This is really really nice Meelobee, looks gorgeous mate. :jawdrop::jawdrop::jawdrop::rock:
  10. Squigly
    20 May 2012
    :eeek: nomnomnom!!! like glass mate, it looks puuuuuurfect!:thumb::rock:
  11. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    awesome paintjob :thumb:
  12. bluc
    4 Apr 2012
    Everytime I look at that paint I am amzed :jawdrop: like lookin into a glass of milk :D As good as any paintwork I have seen done by professional painters on hot rods and show cars :thumb::dremel:
  13. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Awesome work, just awesome, looking forward to finished product :)
  14. Phyonics
    Phyonics What's a Dremel?
    4 Oct 2011
    Fantastic paint work :clap:
  15. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Sweet paintjob those panels look awesome :thumb:
  16. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    Worthy of MDPC easily. Can;t wait to see the finished goods.
  17. Meelobee
    5 Nov 2003
    Thanks alot guys, I'm really happy with the results myself, and it shows that good preparation really does make a difference :) I hope all goes well with the big panel for the right side, it's the biggest piece and the one I'm most likely to mess up..
    And yet another paint update:
    I'm done with the primer on all the frame and all the panels (minus the panel with the mobo, I still need to drill and cut in that.)
    All parts were sanded to P1200 and then got their first layers of primer. After a day I sanded it it all to P1200 again and added the second layer of primer. After it dried I sanded it to P2000 and used a cleaner to get rid of all the fingerprints etc in preparation for paint:
    Now all I need is some decent weather, it's been too windy/rainy to paint outside lately.
  18. shata
    shata What's a Dremel?
    6 Jul 2012
    Meelobee,
    Im interested sponsoring your build I really love the concept, if you have need for some let me know via ebay message. I would contact you via bit tech but you dont have message system enabled.
    Here
    Thanks!
  19. Meelobee
    5 Nov 2003
    Hey Shata, not sure how ebay message works, so I've joined your FB group.
  20. Meelobee
    5 Nov 2003
    Teasertime! (phonepics, sorry!)
    Yesterday I started rebuilding the frame:
    Wired up the main powerconnector & On/Off switch. The blue cable is for the 7" touchscreen.
    Front bar = shiny!
