News ZDNet makes Mac overclock tool
Discussion in 'Article Discussion' started by CardJoe, 1 Jul 2008.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. RTT
    RTT #parp
    12 Mar 2001
    Bollocks, i'm on Tiger. 8 cores at 3.2 would be nice :(
  3. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
    make a version for the imac and the mac book range and we're on to a winner. the pro versions are reserved for the filthy rich, the fanboy and the professional (note that only one of those three can justify the cost of the mac pro)
  4. will.
    will. A motorbike of jealousy!
    2 Mar 2005
    Or make toast on their macs :p
  5. Passarinhuu
    Passarinhuu I huffs cats
    30 Jul 2007
    I don't think Apple will be very happy to hear about that feature...
    Expect El Jobso to contact you soon, ZDNet.
  6. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Quick, grab it before Apple sue the pants off 'em!
  7. TheVoice
    TheVoice What's a Dremel?
    14 May 2007
    The iMacs and MacBooks wouldn't be safe to overclock, they already run hot as it is.
  8. Bluephoenix
    Bluephoenix Spoon? What spoon?
    3 Dec 2006
    no, they have quite alot of headroom.
    they run hot because of the fact they're using a mobile chip, which naturally runs hotter than a desktop one. the thermal envelope still has room though.
  9. Gareth Halfacree
    4 Dec 2007
    Are you absolutely certain you haven't got that backwards?
  10. Timmy_the_tortoise
    Timmy_the_tortoise International Man of Awesome
    28 Feb 2008
    If that's the case, then all of the mobile chip designers should get STRAIGHT back to their drawing boards.
  11. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    +1
    I think you've got that wrong bluepheonix
    Having said that i'm not comfortable OCing my windows laptop so i probably wouldn't a macbook
  12. Timmy_the_tortoise
    28 Feb 2008
    If you want a steaming pile of molten plastic and silicon in your lap, I would heartily recommend Overclocking your laptop, poste haste!
  13. Bluephoenix
    3 Dec 2006
    probably, posting at 7am US EST is not a smart idea to say the least.
  14. Cinnander
    Cinnander What's a Dremel?
    19 Apr 2007
    And a damn sexy pile of plastic it would be too!
    Infact, I bet the magic smoke in Macs even smells good. You know you've clocked it too far when the room is filled with the smell of freshly baked bread!
  15. Timmy_the_tortoise
    28 Feb 2008
    Pop-Tarts if it's an Eee.
  16. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    The stench of death if it's a Dell...
  17. wyx087
    15 Aug 2007
    now my friend can underclock his Macbook Pro, so it won't overheat :)
    Mac's cooling leaves a LOT to be desired, IMO this tool could only be used to solve overheating.
  18. Goty
    Goty Minimodder
    13 Dec 2005
    Tell him to disassemble his MBP, clean out the four or five buckets of extra (read too much) thermal paste, and watch the temperatures plummet.
  19. ParaHelix.org
    ParaHelix.org What's a Dremel?
    19 Jun 2008
    Mac sucks, Linux rules, Windows is okay too, but both are better than Mac.
  20. Glider
    Glider /dev/null
    2 Aug 2005
    Yay, junk to make expensive junk go faster!
Tags: Add Tags
